Installed a Yaesu FT7900 Ham radio with lip mount on the rear hatch. I'm considering drilling the hole for a roof mount... hmmm...
Forgive my ignorance, but what are those for? Reminds me of the Viper launch tubes on Battlestar Galactica.
just additional alarm leds. the one down at the corner is actually wired to the alarm brain status output. the scanner leds are wired to the ground when arm output.
“Smokers Kit” with double 12v’s installed. Easy-peasy. Need to re-wire the other 12v the PO drilled in there instead of just fixing the OEM socket in the original piece.
New wheels to fix that pesky UCA rubbing issue... and a Nux bobblehead that my hot lady got for the rig.
Tested my center diff locker, and 4x4 actuator, cleaned the MAF and throttle body, replaced coolant with Toyota red, got my first scratch on my sliders that I welded on a few days ago. Now to scrub surface rust and paint the sliders and frame around the plates.
Rear diff fluid, transfer case fluid, bearings, lower ball joints, and steering system are all that's left for a total refurbish job. Just might get 35's mounted by the end of July.
Then I can weld gussets to the shock towers and spindles!
Sent from my XT1710-02 using Tapatalk
Replaced the original rear rotors, pads, adjusted the parking brake, and solved my weird “surging” while braking issue!!
Part number?
Would happen to have a part number? How much was it? Plug and play?
The part number is 74110-35010-B0. I literally installed mine in the parking lot of the dealer when I picked my car up in Philly.
Here's a install post from another member.
http://www.toyota-4runner.org/engines-suspension-wheels-tires-audio-accessories/52158-smokers-kit-extra-12v-outlet-installed.html
I got mine off ebay for $23.50 shipped. Would have been less but I wanted it to be at the destination by time I picked up the car so I had to go with something that had a for sure shipping date. You can save a few more bucks if you shop around.
I was actually just looking at these at discount tire this morning and wondering what they'd look like on the 4runner. solid looking wheels on it!
Yep, got 'em at Discount Tire. They knocked off the price of one wheel (I got 5) and the install fee (possibly because I got the BFGs from them the week before). Great customer service with those guys. I'm having more front fender rubbing now with the different offset, but I'll be remedying that with a fender mod later today.
I didn't get a lot of MPG from spark plug change out last month. Wow, cleaning the MAF was easier than I thought. Maybe this will help. 44,xxx
________________
2007 SE V6 Titanium
Got the Rola rack, low profile 4xinnovations mounts, 32in light bar all mounted this weekend.
Mounted my hi-lift, spare wheel, and knock off maxtraxs
Gunna get some locks etc, to keep everything from getting stolen.
Do you have aftermarket turn signal indicators or did you figure out how to clean them. Yours are so shinny and new looking, me jealous!
I did the same thing this weekend! Couldn’t believe that it even got rid of the crazing on my lenses, thought that was permanent. Need some clear right quick. Ordering some Sylvania UV Block Clear Coat.
Also replaced the rear sway bar bushings and end links and installed the newer FJ Springs I’ve had for a few months. Rear diff and transfer case fluid change, oil and filter change, new spark plugs, cleaned up battery terminals, greased the prop shafts (u-joints and slips), MAF cleaned, TB cleaned, inspected brake calipers (no sticky) and regressed the slide pins, and touch up paint on the hood scoop grill. Whew, long weekend.
Now to deal with the front diff drain plug that I mucked up :/. Why oh why did Toyota use a 10mm hex aluminum drain plug on that damn thing? Way too soft for 49 ft/lb
