Cleaned the engine bay today (was much needed ). See the before and after.
Fixed my clunk
Found the problem
Also threw in some new cv's
New ujoints on front shaft
Sent from my E6810 using Tapatalk
well it was yesterday, if you guys follow the facebook post, did my valve cover gasket and also spark plugs and a new belt tensioner. cleaned up the throttle body and maf sensor. looks like my filter might need a cleaning also, to do the belt tensioner, make sure to unbolt the ac line bracket on the left of engine, this way, itll give you more room to move the compressor out the way, also needed to remove the front skid plate to do the compressor.
everyone says i have some very clean no sludge. all mobil 1 extended oil with the m1-209 filter (bigger), this is at 10k intervals.
Replaced my rear window wiper arm. Nothing major but something.
It was fairly major when I did mine. The thing was so corroded/frozen to the shaft that I had to cut the arm off and use a dremmel to cut the bushing off so I could replace it! Took almost an hour total, instead of 5 minutes due mostly to having to drag out tools that shouldn’t have been needed for a wiper change!
Found some little turds in the glovebox and rear drawers, left a cliff bar in there to hide from the dogs a couple weeks and forgot about it. Went full Rambo. 10 traps and a couple hours later, got the little bastard!
Congratulations on a successful hunt!!
Leave the traps in there for a bit longer, a lot of times where there's one there's more!!
That's what everyone's been telling me. Still have 10 traps set in there, no more mice or new turds anywhere but I'll leave it be another couple days.
Let there be light
Did this. Makes it a lot easier to operate at night
Ambrose67
