New tires, more LED lights
I just bought this a couple of weeks ago and it needs a fair amount of work. I can't afford to do all of it at once, but tires and brakes were high on the list. Got the brakes done last week (kind of finished them yesterday) and got the tires done yesterday.
While it was on the lift (I know the owner of the shop, so I get a lot of freedom that customers typically don't) I pulled down some of the plastic in the front wheel wells and replaced the turn signal housings with new ones from Sparks Parts because they both needed it and it wasn't terribly expensive. The drivers side had moisture in it, the passenger side had a bulb stuck inside it and the back of it was rather melted so I couldn't actually lock a replacement bulb in place. Replaced the bulbs with LED and they are really bright, but now I have the hyperflash issue. I would prefer to keep my DRL, but I don't want resistors on there in case I should ever want to put it back to stock. I think a new flasher is in order. I'm thinking about this one. Anyone had experience doing this?
Also, while it was on the lift, I changed out the running board bulbs. That turned out to be a lot easier than I thought it would be, and I love the clean white look, especially in silver running boards. Still wonder why Toyota chose silver running boards for a black 4runner. Also wonder why they don't put clear coat on black. But I digress.
When I said we finished the brakes, there was an issue last Saturday where a parking brake shoe hold back spring was giving the mechanic fits and since it was close to quitting time, he gave up on it. It squealed very loudly for a good portion of the drive home. Luckily, that's a good 35 to 40 minute drive for me, so by the time I got home, it guess it had worn whatever groove it was going to for the most part and was much quieter. Got a new parking brake maintenance kit and me and the owner did the springs without pulling the axle, just like you're supposed to do. We did cuss quite a bit. Then we bled the brakes again and adjusted the parking brake. Since we upgraded it to the bigger Sport Edition front rotors and calipers last Saturday, it now stops better than it ever has before, and I can use my parking brake just like I like to.
After I got home, I pulled the passenger side tail light to change the reverse bulb and turn signal bulb and realized that I didn't have to pull the tail light to do it. So I put it back and installed the new LEDs. I tested and the reverse light was perfect, but the turn signal wouldn't blink even if I turned on the hazard lights. I must need to flip it over. So in attempting to pull it out, it came out of the little holder and fell into the tail light. So I pulled it again and dumped out the LED bulb. Now since I didn't want to keep repeating that, I set the tail light inside the rear cargo area for further testing. It turns out that every time I try to remove the bulb, it falls inside the light. So it's definitely not snug enough in the holder, and it has little tabs on the side edges that catch the opening as you attempt to pull it out. Anyone have any ideas or suggestions for this, other than filing off the plastic tabs that don't need to be there?
Lastly, I changed out the license plate lights with LEDs. I ordered new lenses with gaskets from Sparks Parts but after cleaning the existing ones with some glass cleaner, they didn't really need to be changed.
I have a new project coming up that I was unaware of until I was working on it yesterday...fuel tank straps. Looks like at least one of them has rusted completely through. Still need new rear shocks, A/C compressor needs O-Rings replaced, and it's past due for timing belt. Crossing my fingers on that last one for a bit. Also, none of the keys seem to work the tailgate lock cylinder. I've sprayed graphite lube in there and it appears to be very stuck. Pretty sure I'm taking that to a locksmith and not trying to tackle it myself.
Had a couple of good body shops give me estimates on paint restoration. One of them said that in order to minimize costs, he recommends I get a bottle of touch up paint and touch up the nicks and dings myself, then get a good detailer to work on the sides of the vehicle. he wants to take off the mirrors, hood, lift gate and front fender flares and actually repaint those in the shop. They won't have to mask the vehicle if they do that, and that saves a bunch of money right there. I figure that if I've got to get a hood painted anyway, why not get a hood with a hood scoop? I've always liked hood scoops, functional or not. Maybe some day I could put a light bar in there.
did this yesterday but waiting on a Factor55 to get here.
After the wheel bearing yesterday, got out there this afternoon and swapped out my diff and transfer case fluids. None of the bolts were seized, and the magnets had a pretty small amount of sludge on em considering its at 188k and it's probably never been changed before.
Also removed my front sway bar. It was pretty bumpy with the OME springs and Bilsteins on there, and now it feels awesome. Can't wait to get it offroad in a few weeks once the headgasket is done!
Very frustrated this afternoon. I have an Icon lift I got second hand from a forum member sitting in a box for about two weeks. I finally get around to putting it on only to find that the rear lower bushing and shock mount spacers don’t fit on my 4th gen. I’m not sure what the deal is. I need to contact Icon to make sure the shocks I have are indeed for 4th gen if not to see about getting new bushings. I ended up having to put my Billies back on in the mean time. Anyone with a 4th gen with Icon 2.5 rear with resi’s and CDCV that can confirm the part or SN number on the shocks so I can cross reference? PM me please.
Since I was unable to get the suspension swap done, I rotated my wheels and tires. The front camber is off, I noticed my tires are wearing on the outside, needs an alignment check.
I put on some TRD center caps I got from the classifieds too. I’m not sure I’m sold yet. Opinions?!IMG_1883.jpg
Thanks, its a slow build. sliders are next.
I just installed White Knuckle Offroad sliders, highly recommend. Pics because why not.IMG_1887.jpgIMG_1888.jpgIMG_1889.jpgIMG_1890.jpgIMG_1892.jpgIMG_1891.jpg
Gave it it's first bath since July 4th weekend. Polished up the headlights a bit. Gave the interior a quick detail and, started getting her ready for our road trip on Tuesday.
Went to signal peak here in Nor Cal. Fun Trail and Technical trail. Took me 3.5 hours to get through. Glad i installed those Falken Wildpeak AT3 285/70R17
Camo Wrap and washed!
Camo Wrapped the wind deflector on the basket. washed her and shined up the tires.
with camber..wonder what it handles like...
I looked at it and was wondering why it looked so different. Don’t know how many redditers are on here but this was definitely a r/confusederections for me lol. You can probably drive that thing like Ricky Bobby!!
While a had a few minutes to kill, I filed down the little tabs on the sides of the LED turn signal bulbs so they wouldn't keep catching on the hole in the tail light while extracting them. Here's a link to the bulbs:
https://www.amazon.com/gp/product/B07KZVM2KN/ref=ox_sc_act_title_1?smid=A6M2FHZLRKPJW&psc=1
Once I had that issue resolved, I put the bulb in place and turned on the hazard flashers. Nothing. Turned the bulb over and turned on the hazard flashers again. Nothing. Noticed that the little wire connectors that conduct electricity to the LEDs aren't really making contact. Moved the wires to the other grooves so they would make better contact and still got nothing. It's possible the bulb was simply defective, but I doubt it. Ordered about 40 different LED bulbs from Yorkim and never ran across another one that didn't work.
So a buddy of mine with a 2017 Tacoma TRD Sport 6-Speed tells me he has a bunch of spare LED bulbs that he couldn't get to work when he did his vehicle and that I can have them if they work in mine. So he hands me an absolutely HUGE LED turn signal bulb. I have no idea who makes it or where he got it, but it definitely was difficult to insert into the little holder. However, it worked. So now both rear turn signals are LED. I'm not doing the brake lights because I plan on purchasing tail lights from a 2006 or later and those are already LED brake lights.
I do have hyperflash in a big, bad way. Looking at replacing the flasher relay and losing DRLs. I'd prefer not to lose my DRLs, but I'd rather lose the DRLs than install resistors. Changing a relay is similar to changing a bulb.
Added sound deadener & undercoating to my passenger side wheel well under the hood. (My sound deadening thread explains my rationale.)
Decided to give the driver’s side more thought before working on it b/c of all the brake components. While I had everything disassembled, I cleaned my air intake duct & painted it with high heat paint. Also hit the bolts & clamps with rust reformer. Pics aren’t great but you get the idea.
Before starting
The duct & clamps
First layer
With partial foam layer & undercoating + reassembled
Haven’t driven it yet so I’ll post on how much of a difference this makes.
delislerebecca
