Picked up the signage to switch our site to shots. (They’re only atop the cover because it’s easier to work on the swap at that height, I don’t carry anything there.)
THE PLANDEMIC IS REAL...but is it any worse than the Flu?
Nobody questions why nobody died of old age in 2020.
These vaccines arent your grandparents vaccine. Nano particles can pass thru the blood/brain barrier, alter the genetic code and do generational damage.
You have been warned.��
the plandemic is real...but is it any worse than the flu?
ffs.
I just picked up some signs, dude.
Well...here's what I added to the beast since I got it lol...
1. Rear 2.5 adjustable king shocks
2. Total Chaos complete rear links
3. Stainless steel brake line all around
4. Gobi Roof rack and ladder
5. 40" ridig LED light bar for roof rack
6. Quad halo LED headlights
7. Smitty Built 10k winch
8. 2 Baja designs LP4 pro amber and 2 Baja designs LP9 sport lights for the bumper
6. Switch pros 9100 install with SD offroad mount tray
7. BFP fab lower shock gaurds
8. Full CBI skid plates
This summer, upgrading the transmission cooler, adding dana 60 axles with front/rear lockers and 4.88 Nitro gears
Also, the mirrors were imported from Japan.
Dang, you jumped right down the rabbit hole lol.
Sent from my SM-G986U using Tapatalk
Username checks out......
Installed ProTuningLab's black smoked headlights with their T2Pro LED low beam option today. The original light lenses were not only hazy, but were gettin' fine crazing/cracks toward the bottoms.
Easy mod, just a little tough to get a small 10mm ratchet to the lower assembly screw on each original. Didn't put those back in, but will keep 'em in case there's any rattling. These aftermarket assemblies appear to be well made and fit well. Will need to purchase new OEM trim connector tabs, as half of 'em were so brittle the teeth cracked off upon removal and couldn't be re-used.
Got started on my weld-on sliders finally. Hoping to get them painted tomorrow and welded on the car by next weekend.
Sent from my SM-G970U using Tapatalk
Installed the Daystar 2.5/1.5" lift I got for Christmas. Cost me a bit in larger sockets, jack stands, etc. but I figure those are all good to have anyway. Took about 8 hours total but that's doing half the front, a few tight bolts, and never having done something like this before. Really happy with how it turned out, and found some things that will need replacing in the near future. But I'll do all that with a proper suspension upgrade down the road.
You are a clown.
Installed black Spidertrax 1.25" wheel spacers on the fronts today. Another easy install with no surprises. On my old, mildly lifted '06, the wider stance helped it handle better on our curvy, wet/snowy mountain roads than stock.
If there's time tomorrow, 1.5" spacers are goin' on the back.
Slow and steady wins the race, so they say.
Besides, it was beer-thirty... somewhere. :)
LC80 Snorkel. Not as complicated as i thought. Hardest part was getting all the bolts nice and snug and getting it aligned just right. I think I got lucky with the alignment.
I also put some silicone around the snorkel/body and spray foam in the engine bay hole where the intake goes into the fender.
Tx470
