What does it cost you to do your own oil/filter change?
Kanab
7-qt's of oil and a filter. Buy the grease by the tube. So what does it cost you for the supplies? I figure Mobil 1 runs close to $5 a qt and the filter from the dealer $5-8. So your talkin $40 - $45 every 5K miles doing it yourself? What are you doing yours for?
That is a pretty good guess. I tend to buy my stuff in bulk and at a good price. Costco has Mobil one for 23 bucks for 6 quarts and ocassionally I get better deals, like the Pep Boy deal one of our members found, less than $2.40 a quart. Any thing less than 4 bucks a quart is good in my book. Then I buy oil filters by the dozen at a Toyota dealer, about $4.50 including shipping. You will need a teflon washer for the bolt on the oil pan, about 50 cents. That is about it, except paper towels, WD-40 and of course the cost of the tools. Right now it cost me about $28 to change oil in my 2001 which has a 6 quart capacity.
For conventional oil I figure getting Castrol GTX for less than $1.40 a quart is pretty good, (I use this on my 2 older cars). Right now I have 2 cases of Castrol and 8 quarts of Mobil one sitting around. Oh yes, I tend to pick a non-wet day and hopefully semi-warm before I change oil, but sometimes I have to do it on a terrible day.
I haven't looked at my oil plug but I was wondering about the teflon washer. Do we all have it? Or is this something you've added to the mix. I usually change my own oil and haven't ever had one of these.
G3 Trout Runner
With Mobil 1 oil, a good filter, and some grease in the driveline fittings, I would say between $35 & $45.
Not sure how much oil my V6 takes with the filter? I thought I read 5.2 quarts? :dunno: I'm also curious about the teflon washer?
5 quart jar of Mobil-1 : $19.45, 1 more Quart of Mobil-1 : $3.99 all @ local Wall Mart, Toyota filter : $3.99, Teflon gasket : 85 cents, Done It Yourself and Done Right PRICELESS...;):
G3 Trout Runner
That is a good question. When I got a dozen filters, I bought 6 washers, ( I change them every other time just to save a few pennies). I was surprised to see they were teflon coated and the list price was 80 cents. The washers I get for the Honda and Acura are not teflon and cost 18 cents.
On my 2001 I changed the first oil and the oil plug had a teflon washer on it, so I changed it with another Toyota teflon washer. Remember this is a 3rd generation, but I would suspect that the 4th generation would have a washer around the oil plug. Every car in which I have changed oil has had a washer on the oil plug and unfortunately that is quite a bit of cars.
When I got my parents 91 Toyota Previa I changed the oil and the oil plug had no washer. I suspect the cheap oil change places didn't want to put on another washer and just left the old one off.
Maybe a 4th gen who has changed oil can chime in.
Well... I buy Mobil 1 for my business in 55 gallon drums. It comes out to 3.17 a quart. I buy my filters buy the cases and they come out to about 3.25 a filter. I know thats not fair, but I maintain about 600 cars and trucks in the Atlanta area. Sorry Pitbull...
Dang you got me beat. By a long shot. :upset:
Pitbull, it's me again. How often do you change your oil, and do you do it yourself? Did you say you were going to roll over and let the dealer do your changes....?
I have all of the tools too do it myself (did my Landcruiser and Dodge 3500 CTD) Since I got the 350Z and 4runner, I've been having the dealers Nissan/Toyota do them (just being lazy). I had the Z done at 1000 miles and then every 3000. I had the 4runner done at 1500 miles and then every 3750. The Toyota dealer charges $29 for OC, the Nissan dealer alway has specials so they run around $19. If I do it myself I would use Mobil 1 5w30 and OEM filter and to keep warranty intact change it every 5000 miles on the 4runner. Figure it will cost me around $40 for the oil and filter. I plan on trading the 4runner at around 90K miles and the Z at around the same mileage. What do you think? Should I just keep letting the dealers do them (since I won't be keeping either vehicle forever) and just check the dip stick before I drive away to confirm they filled it up with oil and the oil is clean? Toyota dealer uses Castrol GTX 5w30 and the Nissan dealer uses Mobil drive clean 5w30.
I just did my first oil change tonight at 1857 miles :D.
6 qts Castrol Syntec 5w30 $24
Fram oil filter (I know) $4? (got the off road version)
Went to my bro-in-law's auto repair shop and did it there on a lift. I have my own set of Snap-On tools but its much easier doing anything on a lift. I broke the plastic oval cap that closes the skid plate just below the oil drain bolt. There's also 4 bolts you have to take off the front skid plate to get to the oil filter. At least the skid plate is hinged and swings forward. I like the oil filter placement on the V6s much better. I'm thinking of getting one of those oil filter relocation kits.
One thing I noticed already was some rust on some of the rear suspension parts. I thought this was odd since its only 5 weeks old.
Get that damn Fram filter off your car!!!!! Yea our filter is kinda a pain in the ass, but I have seen worse. My undersides are all full of dirt so I cant tell what shape those parts are in.
$10
(6) quarts of Pennzoil 5w30 - $1/each
(1) OEM Oil Filter - $4
(1) OEM Drain Plug Washer - included
Oil Filter #90915-YZZD3
Washer #90430-12028
I have lifetime oil changes from my dealer and used to get passes for a free car wash. I guess it was to make up for the oil at the bottom of my engine bay.
I would move over to synthetic motor oil, however, since the conventional oil change is free, i don't bother.
