What is your caster set at? Mine has the Daystar and Spidertrax as well. It started rubbing in the front of the wheel well at full crank after I put more caster in to get back within specs. I hated the look of the camber I needed in order to have proper caster. I made them set the camber at 0.0 both sides which cost me some caster. My caster is now outside of spec, but with a good toe setting and 0.0 camber, it drives good and no rubbing. Give it a try before you cut.
