what is part number for bulb in rear window control light?
keakar
edit: other bulbs sorted but now can anyone tell me what bulb does the rear window switch use? i cant find any listing except for the whole switch but nothing shows the light bulb that goes in it
i figured out the climate control mode select 90010-09018 bulb fits in it and will work, but they are different color sockets and the rear window bulb is clear and the mode select bulb is green so i want to find the right bulb for it if i can somehow
i just had the bulb burn out for my climate display screen and realized 2 out of 3 of the bulbs for the control knobs are burnt out as well so thats at least 3 of them burnt so i figure i will just buy a full set to replace them all but i dont know what part number to order.
does anyone know what bulbs these are? the 3 display bulbs are short but the 3 control knob bulbs are sticking out like 1/2" long
ps - not interested in color change, but im not opposed to dimmable led replacements there as long as they arent overly bright, just want about the same brightness as oem
im also thinking the rear window control must have a burnt bulb too because its not lit at all in any way when the lights are on
i havent had this 4runner very long but i never realized so many bulbs were out
i found these numbers but im not understanding what number is for what bulb
88610F BULB, COOLER CONTROL SWITCH
90010-09015 TYPE A:REFER ILLUST. 2 $3.95
90010-09017 TYPE C:REFER ILLUST. 2 $3.95
90010-09018 TYPE D:REFER ILLUST. 1 $3.95
90010-09019 TYPE E:REFER ILLUST. 3 $3.95
90159-50267 *** STD. PART $0.99
this is the link ToyoDIY.com
thanks, i was just coming post that i found thew illustration they mentioned to refer to saying what number goes where
its as follows
part number > type> # of bulbs> socket color> position
90010-09015> TYPE A> 3> gray> long bulbs for round control knobs
90010-09017> TYPE C> 2> gray> short bulbs for display lighting
90010-09018> TYPE D> 1> black> short bulb for mode button lighting
90010-09019> TYPE E> 2> green> long bulbs for defrost recirculate buttons
90010-09015 and 90010-09019 "look to be" interchangeable but i think they are actually different brightness
the strange thing is, the illustration says type A and type E are reversed from what the part number listing says?????????
im just going to match the socket color of what i take out rather then trust what the toyota parts list says
I don't think this has the rear window bulb but it has alot of others.
not really sure about OEM lights and how the part numbers work, but it should be a 3mm T-1 twistlock bulb
i realize you aren't looking for something brighter or colored but if you were to switch to LED the p/n that would fit would be a Neo3. when i was looking for bulbs for my LED swap i found that most of the Neo3's were discontinued, replaced with the Neo3-xHP which is a brighter variant. technically you could dim it with the cluster dimmer control
https://www.superbrightleds.com/moreinfo/instrument-cluster-gauge/neox-led-bulb-high-power-instrument-panel-led/221/1006/
^ link to the site i used
attached is a pic i stole from one of the giant LED swap threads on here that i used for reference
just my .02 hope that helps a bit :shrug:
AndiGarage
