-snip-
I was leaning towards a HiLift, but after reviewing for awhile it appears those are more recovery than anything, and not recommended for changing a flat.
What are you all using for changing tires on the trail? I'm not worried about pavement, but more when off-roading.
My OEM jack is a bottle jack (2017). Was OEM a different style jack in the earlier 5th gens?
I guess I should make sure my bottle jack still works after the lift. New task for the weekend, I suppose.
Edit: Found this if you're OEM jack isn't tall enough.
https://safejacks.com/collections/bottle-jack-accessories
You must have never had a car made prior to 1975 or so.
I know that GM supplied a ratchet style jack for their cars, and they were not as robust as the hi lift jacks are by any stretch of the imagination.
Since you admit you are more concerned with a jack for off road use, you should look at a few accessories for the hi lift: a base plate adapter that makes a larger footprint would be a good place to start.
Of course, unless you are running aftermarket front and rear bumpers and some kind of sturdy sliders, you are pretty limited you where you can actually place the hi lift under the vehicle in the first place.
I've used the OEM bottle jack on mine and other vehicles off road. Worked fine under the axle.
Bottle jacks look pretty lame attached to a Gobi rack though.
I've been using this, and I even take it on offroading trips. I've used it on all sorts of terrain, and even on a muddy trail in the middle of nowhere
Got a link?
Ha ! I'm 55. When I was a teenager these were in the back of every car. I've changed a lot of tires on the sides of roads with them.
amazon sells it, but I've actually seen them at home depot of all places.
You carry this around all the time, or just on the trails? Seems like it would be a huge thing to lug around full time.
Depends It usually stays in my truck 99.9% of the time, the handle is mounted with quick fists to the hatch and the jack stays strapped down with my tool bag in the back corner. The 1.5 ton has a pretty small footprint and weighs maybe 10 lbs at most so it really hasn't gotten in my way and if I need to fold the seats flat all of it fits on the rear floorboard's with the seats folded. Its been nice the couple times I've used to help change random peoples tires lol.
I do need to get around to making a removable extension and the skid plate/ sand float for it (they sell them but I'm to cheap to buy something I can make myself)
I have maybe $200 total in truck tools.
kobalt 119 pc socket set - $24.75 on sale lowes
harbor freight 1.5 ton jack- $59.99 plus 20% coupon
Stanley soft tool bag- under $15 on amazon
beat up makita li-ion impact- $10 yard sale
harbor freight moving blanket- $9
couple shackles- free
a couple crescent wrenches, 3/8 extensions, socket adapters, breakerbar, metric and SAE allen key set, pliers, dykes, bunch of large zipties, roll of duct tape, baggy of bolts and nuts, box of wood screws, pack of jb weld and a tire plug kit, probably some other stuff I'm forgetting in that bag but its all had its use for us before either out shooting and fixing targets, wheeling fixing jeeps, helping some old lady change a tire, or pulling parts at the junk yard.
Old pics. Nothing is strapped down, no tool bag in pic, etc. Gives you an idea of the size of the jack and how the handles mount. Everything usually rides in the driver corner with a ratchet strap. It works okay for now until I get free time to build cargo drawers with a dedicated jack mount which will probably be in 20never.
