What kind of lube do you use? :moon:
zerowkul98
It's time for my V8 Sport Edition 4Runner to have the diff's and transfer case's lubes replaced. Dealer wants $100 per unit, and call me crazy, but $300 for that job is a bit...umm....ridiculous. :redbrick:
Can someone on here tell me which is the best brand and weight I should purchase?
Oh, and how much for each unit?
Thanks in advance!
It's in the manual:
I think 75W-90 is only available in synthetic or synthetic blend.
I don't think 90W or 80W are available any more, but 80W-90 should be fine. 75W-90 might work too?
I read somewhere that it's bad to use synthetic in a differential that calls for conventional because it will cause it to leak, but I can't imagine how that would be true?
Lighter oil like 75W-90 might improve gas mileage slightly and should work better in cold weather.
The transfer case has a Torsen differential, so I would stick with what it calls for. I don't think any friction modifiers are necessary since it doesn't really use friction, but I guess it doesn't hurt if it's in there? Or so they say.
For the front and rear I can't imagine it matters much. It's weird that the V6 front calls for 75W-90, but the V8 front calls for 90W and has a slightly lower capacity. Are they different?
I use Royal Purple for everything. F/R diff., trans. case, engine and coolant. I also only use a RP or K&N oil filter. I wouldn't recommend it if you have high mileage. And if you decide to use it make sure it has Synerlec.
I guess Dealerships are not consistant, I asked in Southern Oregon and it is $60 per unit.
_______________
2007 SE V6 Titanium
Just wanted to say thank you to you guys for the great advice, and the advance code!
Just ordered 8 qts of Mobil 1 Synthetic 75w-90 and some new wipers. All for under $80!
Just wanted to say I appreciate the help. Always have.
It's NOT...urban legends never die.
REE
