What kind of transmission gauge is everyone using?
OBDLink LX from Palmer Performance with Torque app on my Nexus 4. I was using the DashCommand app, but it doesn't read the trans temp.
I'm pretty sure OP means a physical one.
OP -- there's really 3 categories people fall into: ScanGauge, OBDII(Bluetooth+Smartphone apps), or a mechanical/electrical physical gauge from Autometer.
The third option is only tranny temp, while the other 2 obviously provide everything else as well, assuming you don't have a 97.
If your 4Runner is 96-98, you will have to get an actual mechanical gauge. There is no transmission temp sent through the computer to the OBII port.
There have been a few people who buy a $40-50 gauge, and tap in to either the inbound or outbound tranny line.
If you have a 99+, there are tons of options. Scangauge II, apps on your phone with different adapters, etc.
motherfudruckers! I have a 1996, any suggestion on which mechanical gauge would you guys recommend?
Also, does it even matter if I have one or not? I know it's good to have one, but is it really that useful? I don't really tow anything, I don't think I'd ever, its just preventing that milkshake.
Millions of people drive automatics every day not knowing that temp gauges even exist.
IMO, there's no reason for concern unless you're towing or subject the trans to hard use. It's nice to know, but 90% of those that know what their trans temp is just for the sake of knowing never have an issue.
Do you know how hot the transmission supposed to be in normal driving and towing? Some gauges ends at like 220 and some at 300, idk which one should I get.
AutoMeter Phantom series
DSC03171_zps40d03c6a.jpg~original
DSC03170_zps8d47e632.jpg~original
I teed into the line coming out of the transmission.
DSC03169_zpsd14b8f35.jpg~original
Maybe fellow member Kball will post some pics of his. Simple but effective. If I had a pre 99 I'd use a similar set up.
When it comes to physical gauges there are two types, mechanical and electric. Mechanical gauges have a full sweep (from low numbers to high) electric ones normally don't have as nice a sweep unless you buy expensive ones. I wanted a cheap gauge so I bought one for around $15-20. Not as pretty an install as most with electrical but it works for me. Mechanical gauges have a capillary tube attached that can't be taken off and they're normally only 6 to 8 feet long so installation is limited.
Here's my write up.
http://www.toyota-4runner.org/3rd-gen-t4rs/69257-mechanical-transmission-temp-gauge-install.html
I've got the Autometer sport comp series electric gauges and the Dakota Digital sender and aluminum block before my trans cooler. That gives me the hottest temp out of my trans and should tell me if there is a problem. Install was pretty easy too.
I use an AEM Digital Trans/Water temp gauge. Comes with 4 faces plates. 2 for trans, 2 for temp. One is white, one is black.
1.jpg~original
2-1.jpg~original
edcultural
