What part is this and any care recommendations?
screamoon
Hi,
I am an entry level car enthusiast with little to no knowledge about various different parts and what they are doing etc. One of these past weekends as I was cleaning the car from outside I decided to peek under it. I noticed some parts had some rusting going on and I am not sure if it's ok to leave as it is or should I be doing something about it? Also, what are these parts? Here are two parts that I noticed with rusting:
Part 1:
ZyHPY8vBT96WWk21mp98KoabyoJyrVOiRSDx5KKJC6vLMVzrVh8njjGwf5xjQf9E7zQlb1Fe7dEZB0uQBDiZkaomKXtMMQp06_NgcNfuli9Yig_diB1A7UdoruCsT-CLXUlzKKra5jz1wDmWOjAIkXqeGRwhCWenryoxdZbzCrjIIgBZnBnKeZGHGHfauwux6vrH-qfRkM83gJiT1w1CCOBlMDkbFls66iNvv1wGcBDMelLGfwohTuDUqVfggnQndpI0TZ0eocqjD-8DuLN2BeT-Z5Ea2jooX-F6dKnPV45JznVuYMuO9vwXWSyBQScT2uWrCL67sk_H8CjcyCJkyuSZsy5vYxFUbNdq1Ii_66PvCs9qvuFFLvcj0jkDw4wZDxKD6PH6ue-zhd3E8-elvCzaGjl2brh2j0ZEJ0m56mnK7TKDcPFOwF6Aspb26H7SF2ocn17yap6lVb_Mx78GRILmb92K3Yl840zyQosE5jaToiJsSiW1MVRw0w6zT2Ht9yb2hphcWVXZaPZbAd3l70QeiHpof5LTqgWWjzS3IFkpjBEfOHVMUtIIsSH1eiTFPRFy337Fg2sDsOb_lh7F1JO5W9FJs2Baagp1uj5OGc0h3MHuS0FzZLE9NE6Tuq_U2gCmDMljgGM06E7MRBl1vEo=w621-h827-no
Part 2:
IOsXvdhGfETDFPE627kTPUWuuUqFZcN7hs9LnaBmwJ0U5PAsen2Z1R_M1qG55c7cuNfxzfyNHYSeQ1KYdCWxtEyfQNiFvGObGKxU6OmdrVshSGn05193_YKwhFqcUZt5ZnKn1JYnJ7sVQFgBErW6UNUqKQ_R5IE_-FKcqGEuR9LxsfnWjmdpJajlMMz2etFBPXClQMqqeLu0qsUJskBrGZEhvRS4WOY0JAma3fJF6qmNu0bN3UJrPg9_4trbzXeRdX7FleVUsjRcnA6yDEF1smgf-i_gbpayFKHgWt5493ddj2Tm2HS-8SkqYbfbHvBEw4uUUn8Nn8Y0iv3nQX7yL0rN1UHvA0aCaZM73ENtcUESvtXeGoNyQb8s6wL5OWQXNcwQtP7g7S7blqJzrLjlgJJtYI9xQcP62iaPNuz6koiWDtTQJjWJsRoSafedXwoRGxRCneVD6oapODCy_WgogJAfjY1jVzxJhH3L1UuNcQk0qPyQ7hBb_L6mbRFrpusNHr2K3VjpielqZc20vfGYbsekQ6rTo1sWw-PfaFu1WgIgl_oatn_XfzrISevDbUVdda23Nrld5JPUjxbsytvxutlgijSyFSzbhaxPTTyV9hluAy249ABSsSzRXmoosg_ZXaY20DXDrS1jksCPCdjhcZA=w1103-h827-no
PS: this is on a 2017 with 18k miles on it (if that matters).
Thank you
Hi,
Part 1:
Part 2:
Thank you
Pics are no good.
Transfargulation Muffler Bearing
Part 1 is your front pinion flange, Part 2 is your transfer case front output flange.
They typically rust to a certain point and then stops, with the oxide layer acting as a further barrier to more degradation. Unless you live where they dump tons of deicer on the roads, I wouldn't worry about it.
If you do live in one of those areas, you can hit it with some Fluid Film in the fall and spring. No biggy.
Narat
erinobr2000
