What portable air compressor do you travel with?
eHaze
Looking for a small compressor to keep in the rear cargo area. 12v and 110 connections would be nice to have.
It will be either 12v DC or 110 AC. Not both.
How small do you want it? What do you want to do with it?
Small enough to store it in the blue circled area.
Fill car/truck tires, bike tires, rafts...
If it fits in that area it will not have enough capacity for car tires or a raft. It will work but may take a very long time.
Many use a Vair or ARB larger, more expensive unit and those may still take a few minutes per tire if you use it to fill after airing down for off road.
I use a 10 pound CO2 tank; fills in 30 seconds. Power tank has a nice one, I made a home-brew CO2 system. Bought a tank and regulator separately plus hose and ARB gauge/fill chuck.
I use the space you showed to store my snatch strap.
Fill car/truck tires, bike tires, rafts...[/QUOTE]
That's going to be too tight for a decent one I would trust, I've use Viair and TJM with good results for portables
That's going to be too tight for a decent one I would trust, I've used Viair and TJM with good results for portables
This is my first one​ for the 4R and it has been doing a great job so far. I have used it probably 20 times and had no issues. I usually air down about 5-7 lbs less than normal street driving when I go on dirt/washboard/forest service roads and it takes about 10 minutes to get all tires back to street conditions. I'm not sure I'd rely on this if I was doing any kind of serious adventure in the middle of nowhere, but like I said it has been great so far for my uses. And it fits perfectly in the space you want. I keep it there all the time.
http://www.homedepot.com/p/Husky-12-Volt-Inflator-HD12A/203356023
I picked up a Viair 90? I think it is. Works really well. Faster than the guy who was next to me airing up with an ARB single compressor...
http://m.autozone.com/air-tools-and...heavy-duty-pro-power-tire-inflator/837628_0_0
I bought this one a couple years ago. I have only used it a few times, but it does the job. I will say I had to replace the 12v plug, which included some minor soldering. It also seems to struggle to fill my 285/70/R17 tires past 40 psi. I just tested to make sure it fits in that cubby. It does, but it's pretty snug when you try to put the hose in there with the compressor.
Sent from my SAMSUNG-SM-G891A using Tapatalk
viair 88p.
This thing airs up super fast but man these things do get super hot. But the heat is just common for tire inflators. Just make sure these things aren't sitting in direct sun while in use.
Another here for the Viair 88P. Have had it for 3 years now and fit it in that cubby with a shop rag over to conceal it. No issues whatsoever but indeed it can get hot. I belief it has a thermal shut-off?
Compact tire inflator
You will love the compact shape of NOOX Tire Inflator Air Compressor. It is in a triangular shape, so closely-packed that the power cord is wrapped around a center groove.
The best portable air pump for car tires can be powered from a 110 VAC and 12V car DC outlet source, enabling you to charge your inflatables both at home and while on the go.
You can read whatever units you are convenient with, as it comes with four read out scales: PSI, Bar, KPA, and Kg/cm.
It charges up to 150PSI, meaning that besides car tires, it can refill almost any other inflatable you might have at home or while on the go. Air mattresses, airboats, air cushion, trucks, SUV, ATV, bikes and so on. And I love the fact that the different adapters needed for this are provided.
A digital tire pressure gauge and pressure monitoring system ensures that once you set the desired pressure, the system automatically shuts off the pump without overshooting.
The compressor is also for perfect for noiseless pumping as its feet are boosted by soft anti-slip PVC mats that absorb vibration and increase stability.
All in all this pump is convenient for fast and multipurpose charging and its compact shape can fit into small trunk and luggage spaces.
