What the F$7k Just Happened?!?
My flight was delayed and I got in so late last night that I couldn't ask my buddy to loop around again. Renting uhaul trailer tomorrow at 7 am and will update.
So mine ended up not only being a cracked head. The entire engine is done, I am not entirely sure the issue, but apparently my radiator was clogged pretty heavily, and one thing lead to another. Pretty much in the end my whole engine is destroyed. I am devastated right now as I have only had it for 3 months and its done for. I REALLY wish you better luck, I am going to crawl back in my hole and remain depressed.... :ybrick::ybrick::ybrick:
Sucks man. Should you decide to part with it, hit me up. I might be willing to take yet another one on as a project. What the hell, why not right?
I shot you a p.m. but to tbst good luck man I really would hate to see the same thing happen to you. Believe me, I am in a miserable place right now. My 4runner was my baby.
Believe me. When I know first thing tomorrow morning I will upload photos if it is PM or something else. I won't let you guys down.
Packing now to move to my new place in NE PA. The 4runner is still going to be useful tomorrow as a stuff mover.
Yes I hope so too.
And by the way, PBR, picking up that runner would be a third project. Your current one, mine and then that one. :)
Yes I hope so too.
Yeah, I need another one real bad. My wife will probably divorce me. LOL. Let me know when you get yours diagnosed and we'll figure out a day to tackle it.
67223464.jpg~original
tbst,
I feel bad for you. That really sux. Even when we disagree on whatever, I still wish only the best for each of you here on the forum. On the bright side, the engine wasn't ruined.
What I would do is buy as much cheap Dex3 I could afford and in one sitting just keep running new fluid thru the transmission catching the flow as it leaves the cooler line. And even when it's clear go another 2 gallons or more. Then a final 3 gallons with your fluid of choice. Under the circumstances, I would have someone run thru the gears while the fluid is being pumed out.
Transmission flush
I've got to think you didn't really drive very far with the mixture and I wouldn't do a drain and fill either. so possiblly the transmission will be okay. Is there any way you can drain the torque converter? That's where the mixture will be toughest to purge undiluted.
Good luck with it.
Yeah, drain and fill, drain and fill. But if you can't do that in the airport parking garage, at least drain as much as you can out so it's not sitting in there while you tow it. The sooner you get that sh*t out of there, the better the chances of saving the trans.
That was more than necessary on my part; a fight with the GF earlier puts me in a less than jovial mood at the moment.
Since I started trolling YT in 07, I cannot recall one person whose A340 has lasted more than 10,000 miles after the milkshake. But if you want to give it a shot, flush, flush, and flush with about 40 qts of ATF. I would drop the pan first though.
Have you considered just swapping for a used tranny? You should be able to pick up a tranny from a salvage yard for around $4-500, maybe less. You may be rolling the dice a bit with a used tranny, but it is at least something to consider.
