What tire pressure is best?
I think it would be difficult to determine everyone's average MPG if we are not comparing the same trucks (awd limiteds vs. Sr5/trails). The limiteds will inherently get poor fuel economy compared to the other trims.
Sorry I forgot to add that I have a SR5.
Well the first tank of gas doing the math, I got 16.95 MPG doing 70.
The second tank was 17.25.
Total miles was 1,893 and 9 states.
Wish I would of got better mileage, but all and all the Runner was awesome. Very very happy with my Runner! This was my first long road trip and there will be more to come.
Welcome home and happy you made it back safe. Yea, what you got seems within reason. You might even get better mileage as the engine breaks in some more. Who knows.....
I'm really confused. My BFG A/T tires say 65 PSI on the sidewall, which is what the shop that installed them put them at and told me to inflate them to. Reading this thread makes me wonder if I've got them over-inflated.
I ran them down to 40-ish PSI and felt the ride was a little mushy, but at 65 PSI the tires are like a rock. I haven't had them long enough to experiment with different pressures, but I also don't know what they should feel like, as I've never owned a vehicle with LT tires before.
They should feel how you want them to feel. All you have to worry about is not getting too extreme -- especially too low.
If you thought they were mushy at 40ish, then it looks like going too low won't be a problem. From there, add pressure until you like the feel.
Lots of good info in this thread, so I figured I'd post my question here rather than starting a new one:
What's the appropriate tire pressure for the 275/55/20 Nitto Terra Grapplers on a 2012 LE? I'm assuming the Terra Grapplers are LTs -- Nitto's website designates them Extra Load (XL), and the max PSI is 50.
According to the info below, I should put them at around 44 PSI, BUT they're not the same size as the stock tires.
Discount Tires filled them to 38, but I was planning on bumping them up to 40-42.
I know lots of people on this forum have these same tires, so what are you running?
From the standpoint of matching the LTs to the load capacity of the stock tires at recommended pressure, no.
If the LTs are same size as stock, just add 12lbs to door sticker pressure, so 44lbs.
Extra Load (XL) is a reinforced P-metric tire so it follows the same load table except extra pressure can be added to increase load capacity beyond a Standard Load (SL) tire. That contrasts with LT where extra pressure is needed just to bring it up to P-metric load capacity.
I didn't find the exact size in any load tables, but to compare apples to apples, the load index for the Standard Load P275/55/20 is 111, compared to 107 for the stock P245/60/20 and 113 for P265/70/17.
The three tires are actually closer to each other in overall capability than the load index spreads would suggest, but the bottom line is that door sticker pressure should be plenty for the new tire unless you have a preference for adding more.
JB brings up good info. If you are not happy at 38 (which should be just fine for those tires) and your MAX COLD PSI rating is at 50, you can go higher then the door sticker, (since these are aftermarket tires, not the OEM's) but I would not go higher then say 45. (Safety factor for heat expansion) which may not be a real issue, just my opinion. Then test for yourself which is better for your needs.
Here is an example. I run D load rated LT tires. 8 ply. I know, a bit overkill, but they were on sale! My max cold PSI is 65 psi. However, without a heavy load on the truck, if I fill to 50 or above, very stiff and hard ride. Below 40, steering gets mushy and Mpg falls. Optimum PSI for me, 43-45 PSI.
JB or others can confirm or correct me, but I think your PSI issues depend more on tire construction vs. size. How many ply's and materials used vs. just the size.
Good luck and be safe.
Tire Pressure
Tire Pressure is "Pounds Per Square Inch". It should not matter the size of the tire. The pressure inside of them would be equal. If the manufacturer's recommendation is 32 then that is what you should use when driving under normal conditions on surfaced roads. For you guys increasing it 6 to 10 pounds, first you may be exceeding the max pressure indicated on the sidewall, and in the summer time when the heat and friction kick this up another 5 or 6 PSI, you are really exceeding the capabilities of the tire. Since when have you all decided that the manufacturer of the tire is incorrect and that what you think is better. Safety, tire wear, mpg, are all considered in this. You go outside these parameters and you are creating a possible problem.
JB and Jtraskell,
Thanks for the informative replies. I overinflated last night and readjusted them this morning to 42 PSI. Will adjust down from there to my liking. :thanks:
The maximum PSI -- as indicated on my tire -- is 50 PSI. At 42, I still have an 8 PSI safety net.
JB and Jtraskell,
Just so you do not confuse Barry anymore, you did not "overinflate", that would be + 50 psi. You simply increased your psi within manufacturer's specifications. LOL:banana:
Ha, yes, I should've chosen a better word. I meant I put a little more air in the tires last night than I intended so I could let them sit overnight and get an accurate reading this morning.
Once I had a cold psi measurement, I decreased them to 42.
