What tire pressure is best?
what is the factory load index, its the numbers after the size on the factory tires
and what is the load index for the tires you are looking at? 3195 @80 lbs, so 121 load index?
And this is the link i actually meant to post:
https://static1.1.sqspcdn.com/static/f/589830/23447320/1378330097907/discount+tire+inflation.pdf
basically the same info but i like this link the best
Original tires Bridgestone dueler HT D684 II P265/70R17 113S
Changed to Nitto ridge grappler LT265/70R17 E 121/118Q
So standard load tires load index 113 at 32 PSI - 2299
With a E tire 121 load index to match 2299, interpolate between 45 and 50 lbs and get a hair over 46 psi
i'm assuming that day to day you aren't driving near your vehicles max weight, so you could try dropping that a few psi and check tire wear
Saw the new chart you posted. I have been running 40 psi. Will bump it up to 45 and see how it goes. Thanks for the info!
