What tools do you suggest for checking front toe-in at home on your 4runner?
Status
Not open for further replies.
mom
Banned
In another thread, it was determined that my 2WD 4Runner needs, at the very least, to have the front alignment retested.
- Advice sought for the likely cause of premature front right tire wear (11k miles)
As noted, the best tools of the alignment shop are for naught if/when the mechanic is sloppy; so I will check the toe, myself, at home first.
- Toyota 4Runner alignment specs
Running various searches on this forum such as a 3rd-gen-title search with "DIY" & "Alignment", I'm surprised I haven't (yet) found a comprehensive 4-runner-specific home-alignment DIY (it must exist but I just haven't found it yet).
So, first (basic) question is:
Q: Where is the best 3rd-gen 4runner front-end alignment DIY on this forum?
Luckily, I can find plenty of front end alignment DIYs on the net; so at this point, I'm at the stage of finding the right tools I need to purchase for a home DIY alignment at a reasonable price:accuracy ratio.
There are LOTs of different tools suggested, and some are at a reasonable price point for a home DIY - but before I buy - I'd like to ask your learned advice.
Given that there are three basic methods of testing toe, each of which uses somewhat different tools:
- Toe Plate method
- Toe Bar Method
- Tire Scribe Method
The topic of this thread is:
Q: What tools do you use to check your front toe and where do you buy them?
What I do is take two pieces of straight bar stock, at least three feet long, and bungie them to the outside of each tire, perfectly level, perfectly centered. Then I measure between the tips before and after the tires, and adjust as needed.
Status
