What's a good way to remove oil stain from driveway
It's actually gear oil. I got it on the concrete today. The concrete is not even a year old.
So far, I used dish detergent, simple green , water..... but there is still a small stain!!! Not that big. Probably 6"x6"
i Spray a all purpose cleaner called Red Hot made by auto magic down on the spot then hit with the pressure washer. It's always worked for me
Try Dave's Insanity hot sauce... it'll remove it. You will need quite a bit depending on the size of the stain. It will even remove wax from floors.
And yeah, I'm being serious.
Good luck
As the title says.... what's a good way to remove oil stain from driveway, concrete
Use Pour-N-Restore. I've used this for almost 30 years. Use it on concrete, never on asphalt. It's a thick white liquid that smells like oranges. Pour it on the stain so it's 100% covered and let it dry. Don't touch it again. As it drys it pulls the oil and stain out. It will go to powder on its own and leave a moist spot that is just water. As it evaporates, the oil stain is gone.
It just works. I use it for new fresh drive way spots from visitors. If you're trying to remove decades of stain, it might take several tries.
If you've already tried to clean it, this may or may not get it all. If it's fresh untouched stain, this will remove 100%.
PS, I buy it in the gallon jug. Don't let it freeze in the garage and shake it up ever 4 months or so.
erinobr2000
