Wheel Help
Thorgan112
Fast question everyone,
After a lot of reading I finally understand offset and backspacing. Now I have one more question before I pull the trigger. Anyone know if the Tundra brake upgrade will fit if I am running 16"*8" wheels with a -6mm offset and 4.5" of backspacing!!!!???? Any help would be great!
I REALLY suggest you start using this ---> http://www.toyota-4runner.org/3rd-g...te-search-toyota-4runner-3rd-gen-section.html
To answer your question, read post #3 of this thread ---> http://www.toyota-4runner.org/3rd-g...ements-231mm-13wl-tundra-calipers-rotors.html
Just in case that wasn't easy enough:
This was taken directly from BFAD's write up.
"Finally, Regarding my wheels:
I am running ProComp model 8069's. They are 16x8's and they have 4" backspacing. The equivalent offset is -11mm. These are one of the few aftermarket wheels that are known to fit over the 231mm calipers WITHOUT WHEEL SPACERS! I am trying to avoid spacers on this rig at all costs, so this made me very happy.
Thanks go out to 4-Ripcord for letting me do a test fit with my wheels on his rig before I layed out the cash!!! I know they worked Rip, but I was still a little nervous. Thanks again amigo!
Quote:
Some info on which wheels will clear the 231mm Tundra Caliper WITHOUT spacers (Just using the quote format to make this stand out):
OEM Wheels that have been confirmed to fit over 231mm Calipers:
17" 6 Spoke FJ Wheels PIC
Base model 4Runner, 6 spoke steel wheels (reference: Wheel fitment with Tundra Brakes - YotaTech Forums)
OEM 4-Runner "5-Star" wheels PIC
OEM 4-Runner 5-Spoke "Flower" Wheels, found on '01-02 models PIC
OEM Tundra/Tacoma 5-Spoke Wheels PIC
OEM 4th Gen 4-Runner 6 Spoke 17" Wheels PIC
TRD Ivan Stewart Wheels PIC
FZJ 80 Wheels will NOT fit over 231mm calipers, unless you run at least a 1/4" wheel spacer.
All of these wheels will clear the calipers, according to this thread >>> 16" Wheels and the Tundra Brake Swap - TTORA Forum
16x8 Pro Comp 1059
16" Procomp 8069
17" Procomp 8069
16" Wheeler's Type B
And all of these will clear according to this thread >>>> FJ Crusier Wheels with Tundra Brake Upgrade?? - Page 2 - YotaTech Forums
Ivan Stewart Wheels,
MT Classic
MT Classic II
Procomp 8069
Procomp 8023 in 16x8
Procomp 7089 17"
FJ 5-spoke (with spacers)
Weld Racing Renegade
The following wheels have been confirmed to clear 231mm calipers by T4R.org members. Do a search for their builds/posts if you want to see some pictures.
17x8 König Countersteer Type-X (Thanks, 4Ripcord)
16x8 Sidewinder wheel by Weld Racing Wheels (Thanks, Dmart 808)
16x8.5 Level 8 Strike 6 Wheels (Thanks, Tylerbaird & Blcktpgsr)
16x8 Vision 375 Warrior Wheels (Thanks, theizzardking)
17x8.5 Stealth Custom Series "Stealth 6" (Thanks, SCS...SCS's T4R.org Sponsor Sub-Forum)
16x8 Stealth Custom Series "F-5" (Thanks, SCS)
Any others that people know of? Send me a PM and I'll add them to the list!! Thanks!"
