. . . I read this thread a couple of days ago, and realized that Harper dug up the correct torque spec (82 ft/lbs) . . .
Hmmmm . . . I thought the Owner's Manual called for 83 ft/lbs.
I don't think 2-3 lbs over would make a difference. Even our high dollar snap on torque wrenches at work here in the engine shop have a tolerance of +/- 3% when they get calibrated every year. Our engine manuals allow up to 5%.Well, I broke 2 wheel studs tonight (1 on each front wheel) while putting on my FJ Cruiser wheels. I removed the OEM wheels/lug nuts with an impact gun, but when putting on the new wheels/tires, I used a ratchet/21 mm socket to snug the lug nuts, (lowered the jack) then used my torque wrench set at 85 ft/lbs. I read this thread a couple of days ago, and realized that Harper dug up the correct torque spec (82 ft/lbs) so I assumed that 85 was OK. WRONG ! I didn't think that a couple more ft/lbs would matter, but apparently it did. OR, the OEM wheels studs are soft, weak, or if you prefer, junk. My 2010 4R has 19750 miles on it, and now wears Cooper Discoverer AT3's, LT 265/70/17 (6 ply) mounted on FJ Cruiser 6 spoke graphite powdercoated wheels. Its going in to the dealer for a 4 wheel alignment, and to replace the 2 broken studs next week. I will mention to the service writer the complaints about these wheel studs on this forum. I don't know if it will do any good tho'.
I'll throw my expirience in. I had a tire shop snap one of my studs when installing my new tires, well when i took it to toyota to have it replaced they got in contact with corporate, kept the vehicle, and said they were directed to replaced ALL of the wheels studs. They also said they were told not to use the ones they had in stock but were overnighted an entire new set. never got an answer on why the were drected to do this though.
Discount Tire just broke one of mine off after road force balancing the tires :bigok:
It is getting replaced tomorrow on their tab, but the plan was to pull my camper out at 7am for some fishing for the weekend. Now I have to wait until the shop opens at 8, and around 30 minutes install time. Not really happy about this. With any luck the shop will not break something else and leave me stuck here....
