swimmerdude1127
Question for you pros out there...
Right now I'm running an all stock '13 SR5 with the exception of new wheels (17x9 Black Rhino Imperials with -12mm offset, giving me 4.5" backspacing) with 265/70/17 Cooper Discoverer ATP. When I first had the wheels/tires installed at Discount Tire, I had a shimmy in the truck at about 65-85mph. I got them re-balanced at a local place (Treadquarters, which Discount Tire reimbursed me for --- excellent customer service by the way), and when they did the work they said all 4 were out of balance initially. Now I'm experiencing shimmy at about 45-65mph. I just now realized they didn't RoadForce balance them at that particular shop the second time.
The weird thing is the shimmy/vibration is not always consistent. Sometimes it will do it and sometimes it won't. I will say that after having them balanced the last time it does it less often.
I just got back from a well-reputed 4x4 shop here in VA Beach. I was explaining my problem to the guy and he told me that it could have to do with the lug nuts. He said that most aftermarket wheels include standard "tuner" lug nuts which are not very robust and aren't good for the wheel long-term because the conical section isn't big enough (I think). He said because of this my wheel may not be centered and I should go with ET (extended thread, I believe) lug nuts. I was under the impression that ET lug nuts were only for use if you were running wheel spacers... so the lug nut could penetrate through and still have threads gripping through the spacer, if that makes sense.
Any insight or tips to help me smooth out my highway ride? Anyoine else had issues with this or changed out their lug nuts when they got aftermarket wheels?
Thanks a bunch for reading... just trying to smooth out my highway ride a little.
