Wheel spacer limits?
BucknutBob
Hey all you techies out there, I've got a question: after installing a 4" SAS suspension, and then a 3" body lift to accomodate a Chevy V8 (absolutely necessary for distributor and header clearance), the truck is taller than I'd prefer. I am planning on getting wheel spacers to wider the stance, and was wondering if there's a limit on how far out the Yota axles will stand before causing complications with bearing loading, etc.. I was thinking of maybe 1.5" spacers, for a total of 3" wider track. Any suggestions? The budget won't allow radical changes for the foreseeable future, so wholesale changes are not in the cards at this time. Thanks!
I ran 2" wide spacers for years on the rear of an S10 blazer with 33"s with no problems but I didn't run them on the front. I did quite a bit of semi-serious off roading without incident but I would be hesitent to run em on the front due to the side/lateral loads involved when steering and cornering. My 2cents.
Thank you so much for the input! Yeah, the front is the one that concerns me the most, especially with running a locker. Appreciate it!
I run 1.5" spacers on the front to match the width of the later rear axle I swapped in.
But I'd never go any wider than that.
The thought of a 3" spacer scares the f^&( out of me.
Ever thought about running IFS hubs?
widening a 79-85 toyota SFA without wheel spacers - YotaTech Forums
attachment.php
This is my plan when the solid axle goes in. I guess you could run a spacer on these too, but that pushing things pretty far out there.
Thanks, fourwd! I agree, the idea of adding that much space past the hub would make me anxious. There's already so much stress there, what with the weight of larger wheels and tires--under power, that seems like the axle would snap like a twig with an extra 3" behind each wheel. Great input!
There are ways to beef up that axle if it is a concern:
Rock Assault
Toyota, Suzuki Samurai, and Jeep Off Road Parts
Thanks again! Right now I've been burning up the bank account getting the engine swap done, so I was looking for inexpensive aids like spacers for the time being. The front axle has the Trail-Gear gussets and armor plate now, and once I can, I was thinking of getting something like Trail-Gear's "Dirty 30" birfields in front. I won't be getting too crazy on the trails just yet, but I wanted the spacers for any off-camber stuff I may run into as part of ANY wheeling. I will definitely be looking into other strengthening aids down the road. I appreciate the tips!
I think with that v8 and stock birfs....you might want to start saving for those dirty30s.
That's an affirmative! I fully understand the implications of cranking on the power right now--that's why you won't see any rock-crawling pics from me right away. The engine is staying stock, but even then, it's a LOT more torque than what was in there. Front and rear axle upgrades WILL be in place before I get too nutty!
