which direction to unscrew the two rotor bolts on each side of the front brake?
knn2
Hello Everyone; Please help me!
i am trying to remove the front rotor but the two bolts are so hard to remove, question?
* on the passenger rotor side, do i turn the bolt clockwise or unclockwise to UNSCREW it?
* on the driver side, which way do i unscrew the bolts?
i have been trying for couple hours on each bolt and nothing moved, i also damaged on of the 17mm socket too.
Please help, thanks so much
In that size range you should be using a 1/2" drive socket.
For a really tight bolt use a 6pt socket with a breaker bar.
I've always been taught... lefty-loosy, righty-tighty.
:biggrin2:
And yes they are standard threads, so the above applies. I remember the exact bolts you are talking about when I changed my pads. I had a cheap socket set and broke 2 sockets before I got them loose. I now have invested in better tools.
finally got it
Hello all;
thank you so much for all your reply, i finally got them loose this morning, the next rotor job should be easier!!!!!!!!!!!!
thanks again.
