which external cooler would be better??
hdoggie24
Member
debating between tru-cool 4454 and the b&m 70264. they both are about the same footprint just the b&m being 2x as thick. i live in az so for about 5-6 month its 100+ out here. read something as don't overcool your atf fluid. would tru-cool suit me out here or should i spring for the b&m 70264 since its rated higher. read many posts just want to get a straight answer. thanks
I wouldn't worry about overcooling your trans, especially in your area.
But the big question would be, what are you trying to cool?? (what engine/trans do you have)
The next question would be are you towing something? and if so how much weight?
ive got a v6 automatic in my 97 4runner. not really towing anything yet. just me, the wife and 3 lil boys and our stroller/gear/etc. so nothing major. if anything maybe in a year or so we would trailer a waverunner a few times a month.
That isn't enough to worry about. But if you still are, just about any aftermarket cooler would suffice.
I added a small one to my Trooper, but I use it to tow my 84 when I go play in the rocks.
In your area an aftermarket cooler is a good idea. I agree with fourwd1 mostly...
If it were me and I had a 3rd gen I might opt for the bigger/thicker one and eliminate the fluid flowing through the radiator. Some 3rd gen radiators tend to 'break' and allow trans fluid to mix with anti-freeze:wow2:
By using the thicker/larger cooler you can get two birds with one stone, better protection for the trans and eliminate the risk of the pink milkshake.
:cheers:
Absolutely bypass the stock cooler (in the radiator), the tranny line in the rad rupturing is possible in any vehicle.
