Which lower links to buy?
Hmm, weird. I am assuming you tightened the bolt to spec and used a nyloc nut? They definitely should not be moving while you are driving down the road.
The bolt is still tight. I may find out when I remove them to put on the RCI skids. At that point, the problem will be fixed as those bolt to the stock bracket through the link and to the frame.
How do the TC skids mount? I just assumed they mounted through the bracket with a longer boot like the OPOR ones.
Lower link choices
If you are banging up your lower links, I would definitely spend a little bit more and get the link bracket skids as well. I run the MT offset links with the OPOR link bracket skids. They work well together and take some abuse. Good luck with your choice. Worth the small investment IMO.
Agree with you here.
I found this thread and all the posts very helpful. Thanks to the OP for starting the thread.
