Which one would you pick?
Bilstein options
  • Set front to 0.85"
    Votes: 3 42.9%
  • Set front to 1.75" and keep rears stock
    Votes: 0 0.0%
  • Set front to 1.75" and add 1.5" rear coil spacer
    Votes: 4 57.1%
  • Total voters
    7
  • Poll closed .
265-70/17
Billys @ .85, nothing else.
I wanted it level and nothing more, perfect in my eye.
Thxs for the photo, u look like u have reverse rake but it could be the angle or the pic is with the truck not on level ground???? Do you have any others, maybe closer? Could u take another photo, I would really appreciate it??? It's hard to judge from that photo..... Il pay u with this :girl: lol
I posted a short time ago in the lift section. Bilsteins @1.75" + OME 895E coils in back. No problem if I need to load up the back or tow.
ok, im confused. I measured the rocker panel to the ground in back of the front tire and in front of the rear tire on level ground. They both measure the same distance. I would think the rear would measure higher then the front...ie rake. Which would make me think increasing the front would in theory level the truck. I dont think you would measure from the tire to the finder because the cutouts are different. The rocker panel should be the right spot...? Am I missing something? :ybrick: Where did others measure? I made sure the ground was level, no pitch.
