Which pins to use for VSC off switch
alex56
So, I've been rolling around with my VSC wires unplugged from the master cylinder for some time now (vsc sucks!!!!) and read about the mod where you can add in a switch to make it more formal yada yada yada
So I bought the switch # 84988-35070....
I understand how to interrupt the circuit by splicing in a wire but how do I connect my interrupting wires to the back of the switch? there are 4 pins to connect too
Thanks for the help,
Alex
If I'm not mistaken, that's a momentary switch and not an on/off switch. Not gonna work unless you modify the switch.
As for the pins, is this the mod you're going for?
VSC Disable on Pre 2008 4Runners - Toyota 120 Platforms Forum
I already modified the switch to stay on constant, I'm just not sure about the 4 pins... I'm assuming 2 are for a power/ground for the light bulb and the other 2 are the accessory (Hack) slots in this case I just am not sure which pins should be hooked up to what
I'm sorry, I interpreted that wrong- I thought you were looking for which wires to hack into in the 4x4 computer.... My bad
Look at the LED in the switch, you can trace the pins (Pos & Neg) from it. That's just the switch light. Of the 2 remaining pins, one goes to ground and the other taps into the wire from the 4x4 computer.
I have a similar switch and I started the mod myself, but haven't spliced the wire yet. Switch light works with other buttons though...looks perfect...
H.Sikina
