White shepherd and transfer case
tacticalcustoms
So I ran this stuff yesterday and seemed to do the trick but nowhere does it say to flush afterwards or just leave in. Can someone give me there two cents:boink:
I did it just like ARK and left it in. I have had 2 drips in 2 months compared to daily puddles before the white shepherd.
update
okay so now its been a couple days and the leak has gone from a 2-3 inch circle to about the size of a quarter if that. I'm pleased that it seems to be working and it only cost 20.00 compared to the repair cost of a new actuator. :guitar3:
Keep driving it and work the 4hi/lo and diff lock to keep the sealant moving and filling the gaps. Also wash/clean the transfer case because most of the drips coming after the treatment is residue dripping from the skid plate.
My update from using the White Shepherd (WS) in the transfer case for the actuator leak.
I developed a rear output seal leak (seal between t-case and rear d-shaft) about 2 months after adding the WS into the T-case. I had the output seal replaced and kept most of the gear oil (with WS added) in the T-case. The rear output seal leak returned after a week after it was repaired. I drove around with the rear output leak for 2 months routinely topping off the t-case with gear oil at every gas fill up. I did not notice any oil leaking from the actuator. I finally went to a different shop (thinking the first one screwed up) and had the rear output seal changed again. When they pulled the 2 month old seal out it was swollen to almost 2x its normal size. I told them about the WS and they said that it must have swollen the seal and caused it to fail. So they drained the gear oil out of the T-case and noticed the WS settled on top of the gear oil in the drain pan. I am guessing the WS stopped the actuator leak but caused this leak. The shop said to watch the front output shaft because if the seal has swollen it will fail at any time too.
So all of you that have WS in their T-cases be warned. You should drain and fill with 100% gear oil ASAP. I am going to write to the makers of WS and see if they can do to prevent this.
ghengiskhan
