Who is running BFG AT/KO's on their 03 and up 4runners?
You won't be able to run chain's as prev. stated.
Just curious , why are you so reluctant about a 265/70/17 size ?? (You probably stated it already....lol) Alot of people have them here.
MJ
MJ
Don't need chains if I have an A/T tire that meets the severe snow requirement and the chain law is put into effect.
265/70/17s are looking like my best option especially if I want a bfg AT Ko on it.
Another benefit would be more sidewall protection and a little more ground clearance.
I know it will effect the speedo which is one of the things I was trying to avoid.
How does it effect the shift points especially when driving up a grade with a heavy load?
Your right I am seeing more and more people with them. Most say they fit fine. I thought I heard one guy say he had only a little rubing while backing up and his wheel to the lock. (hopefully he did not hold it there too long)
Do they fit with the mudflaps? If a few people running them can say they don't rub at all....... I may go that way also since it would be the easiest.
I don't mind you askying why at all. You may just help make me realize that the decision is much easier than I am making it to be.
:cheers:
The dunlop Radial Rover RVXT
the Goodyear wrangler silent armor
And the bfg at ko's all meet the severe snow requirement and are designated as A/T tires. They are all available in the 265/70/17 size.
Anyone have any experiance with anything besides the bfg's?
The goodyear silentarmor are about $30 cheaper per tire and have a $40 rebate on top of that.
I may just stick with the bfgs unless someone can say very good things about one of the others mentioned if I do get a 265/70/17 tire which looks like my best option at the moment.
Thanks for taking the time to read all my thoughts and give your advice. I really do appreaciate it.
John
Another curious ?........lol
What year is your truck and do you have a v6 or v8 ?
Just wondering because I want to buy an 06 & can't decide on a motor choice.
Bluto said:
I think some members are running 16" steel wheels with snow tires. You could probably get a steel wheel and snow tire package cheapers than a set of KOs. Would that be an option? Assuming a snow tire is better than a KO in the snow.
I'm one of those. I have LT275/70R16's BFG A/Tko's on 16" T4R stock factory steel wheels (surprisingly good dealer price; part #42611-35231; cone nuts part #390942-01007; center caps from Ebay.) Not sure which model you have (16's will not fit a Sport; no brake clearance) but these fill the wheel well and there is slight interior rubbing at full lock (rarely happens; they clear the mudflaps.) They are noisier than I would have liked but you already know what they sound like. I've seen posts complaining about wet traction but I haven't had any issues (took the freezing rain crap from yesterday no problem.) They are classified as a snow tire and snow hasn't stopped me yet.
As for Revo's, I'm not a Bridgestone fan. Not saying their bad, but my gut feel is the Michelin and Goodrich casings are better built (run better; dissipate/handle heat buildup better) for the long term. FYI, Continental tires are THE worst casings. Don't buy their crap, period.
Kmvreter, could you post some pictures of your steel rims? I didn't know that 4Runner has Toyota OEM steel wheels.
Well I got the 06 V-8 sr5 . Mosty cause I had a 5.0l In my explorer and loved the low end torque driving though the mountains.
I will say that the 4runners v-6 is pretty darn impressive and would do fine. It also cost less.
I would like to learn more about the reliablity records of these two differnt powertrains myself.
Thanks for the part numbers. I would love to see a pic if possible.
I have the 06 SR5 so I should be good. If I stick with the 265/70/16 size no problem except there is no bfg atko:( I assume thats why you have the 275?
I never had a issue with them either. They performed great at everything I threw at them including snow and ice. I drove an awd explorer with 8 inches of gound clearance through 32 inches of snow no problem. I felt like a snow plow with out a plow! I did have about 500-1000 lbs of tool in the back at the time so it did help. If any of you know the town of Carbondale, CO then you probably know the area up past the resivior on upper cattle creek rd.
As far as I know from dealership mechanics and mechanics from different mechanical and body shops, 4Runners V6 is very reliable and well done. It's also easy to change the oil there and check point are good visible. I can't say much about V8, because I have V6 and was asking about it, but I don
I'm forum challenged as far as linking back to the thread. I posted pics last year in a thread called "Bigger Tires on 2004 SR5?" (post ID #84157???) Also, I posted some in the gallery so search there under my username.
{Edit: Check for the thread in the link in my signature.}
I was researching wheels, tires, sizes, prices, etc... There is a LT265/70R16D (product code #41561.) Decided to go wider and taller instead of just taller. They fit and fill the hole.
Thanks for the info on your thread I'll look it up.
Are you saying the BFG At/ko's come in LT265/70/16? I didn't think so but now I am going to check again. #41561 is the product code for these? Or am I confused.....:confused:
edit- you are right. Now I would like to find a Cheap set of 16" wheels that will fit. Hmm some cheap "16 inch steel wheels would be great.
The standard 16"s are 16x7 correct? Does anyone know the off set and back spacing so I can match the demensions up with the oem wheel?
Thanks again.
