Who is running EBC Yellow Stuff pads on their 5th Gen?
cbielat
Senior Member
I need to buy new pads and rotors real soon. I was thinking of the EBC Yellow Stuff. Anybody running these or have any experience with them? I was taking into consideration the times I go off road as well. On EBC's website, the descriptions don't mention the pad having any carbon ceramic materials in them(or I understood incorrectly). I understand with a carbon ceramic pad/rotor, they perform better when heated up. I want a much better braking experience from the current stock set up.
Thanks guys!
Not to beat a dead horse, because I think it was you in the past that might have asked this question? But usually when you go up to higher heat capacity brake pads you sacrifice initial bite, because as you said they need to be heated to perform better. If you're concerned about better braking experience off road, I dunno how well this is going to help you over stock pads, unless you like to off road down steep hills at high constant speeds, lol.
But seriously, what I mean is it's going to really suck if you run a pad meant to operate at a higher temperature, in the cold. They will not grab as well when cold, they will squeal in the cold, the list goes on. Been there done that in my younger days.
Believe it or not, not many pads out there beat the initial bite of the factory pad, because that's exactly what they are designed for...to stop you RIGHT MEOW, and at any given time. Unless there's something extremely inadequate about the OEM brakes, I would leave them alone to be honest.
This is just a rule of thumb I use when analyzing the brake pads...if your ABS kicks in during a panic stop in the dry with the OEM pads, a "better" brake pad will stop you no faster (because it would just activate ABS modulation sooner). Higher heat capacity pads are really directed more towards if you are experiencing brake fade such as from towing heavy loads and need to constantly stop, etc...
If your concern is the brake feel, I think you need to look else where, like stiffer steel braided brake lines and what not. But even that might be a lost cause with these super advance brake master cylinders we have on our truck.
I know that feeling though, you're due for replacement and rather invest that money towards "better" aftermarket parts, I go through this battle all too often with myself, lol.
[MENTION=85512]eddiebx[/MENTION] Ha yeah I may have asked this in the past. Good memory lol. You have opened my eyes to some interesting facts. The ABS system with a stronger pad equaling the same result as with a stock pad under panic braking. I've felt this a few times since I've had my truck. I still am not 100% set on the Yellow Stuff yet, still researching. EBC's Green Stuff may be an alternative but I keep thinking I'll just go with stock Toyota pads and rotors. Even the TRD pads aren't that worth it when talking with my cousin who runs the parts department at one of my Uncle's Toyota dealers. I just want a little better stopping power with the added weight of my tires, skids and sliders. I can't even imagine how stopping feels for the people who have added steel bumpers into the mix. I hate being so indecisive.
Thanks Eddie!
