Why does p rated tires support more weight than c?
I'm confused! Why do p rated tires support more weight than c? Wtf?
You have a right to be confused. It depends on size, width, construction, etc. As a rule of thumb for a tire the same size (say our OEM size) a C will normally have a higher load rating than the OEM P rating. It really can get confusing quick if you do not compare the same exact tire in the same exact size from the same manufacturer. Read this Load & Inflation Tables | Toyo Tires (click on link for load tables in middle of page to open .pdf file) first for a general tire education 101. If you do not care to read it and understand it you will have to rely on strangers on the internet to answer your questions and hope they know what they are talking about.
I'm confused! Why do p rated tires support more weight than c when the same dimensions and psi?
Because they create and retain less heat and use rubber formulations more compatible with flexing.
Comes from <a href="http://www.toyota-4runner.org/general-discussions/110300-ask-tire-engineer.html" target="_blank">this</a> guy.
I read it. Bottom line is that the stock size c rated tire maxes out at 2470@50psi. The stock Bridgestone max out a 2535@44psi. Correct me if it wrong.
Go back and do a text search for the word derated. The 2535 is really 2305.
Seems like if I went LT tire, E rated is the way to go.
Gonna be smuggling gold bullion in lead urns or something?
As Jeremy posted earlier, the load ratings for P rated tires are reduced by 9% when used on trucks and SUVs (per the tire manufacturers). That means that your stock Bridgestones ratings are really,
rating = 2535 * .91 = 2307lbs (which is less than the c rated tires)
Why do you need he heavier rating?
I don't need to support more weight, but I want to ensure that I'm not not going to a tire that supports less weight.
I did see the line about the weight reduction for p rated when put on a truck/suv.
It all makes sense now! Thanks! C rated would be more than sufficient.
