Why is this so hard to find....
kylemorgan808
Aloha guys, I have and 86 SR5 4Runner, and when i bought it, it was missing the plugs in the floorboards. There is no carpet in the truck and without the carpet and the plugs, there is just a hole to the world..... Sorry for the horrible description but can anyone help me out?? Also looking for a rear window switch. Mahalo guys!!!
I think this is what you're looking for.
57411A MEMBER, FLOOR SIDE, INNER RH
57411-89103 1 $169.14
57412A MEMBER, FLOOR SIDE, INNER LH
57412-89105 1 $169.14
58139 COVER, FRONT FLOOR SIDE, REAR
58139-89101 2 $27.28
58191 FOOTREST, FRONT FLOOR
58191-89101 1 $17.91
58286 BOOT, SHIFT & SELECT LEVER, NO.1
58280-89107 1 $82.67
90159-60112 *** STD. PART $1.19
90189-06029 *** STD. PART $1.27
90333-35002 *** STD. PART $2.10
90950-01061 *** STD. PART $3.32
90950-01086 *** STD. PART $5.14
90950-01234 *** STD. PART $6.48
90950-01352 *** STD. PART $5.10
90950-01398 *** STD. PART $1.27
93560-56020 *** STD. PART $2.02
I could be off on the part, it's hard to tell in the diagram. Either way they would be somewhat cheap at the dealership so they will be the best ones to talk to. Or you can measure the hole and just find a rubber solid grommet that fits that hole in the floor.
Thanks man!! My local dealership seems to be full of parts managers that cant tell a nut from a bolt... (true story, happened when getting driveshaft bolts), so hopefully i can give em a part number. Thanks man!!!
Don't take a lot of faith on that part number. I'm not saying the part number is wrong but that diagram has a few plugs. If you go to the dealership and order the wrong plug, will they give you a refund if they don't fit? From what I can tell, that diagram has 3 or 4 different size plugs.
kylemorgan808,
Are you talking about the plastic/rubber ones to "drain" the cab if it gets flooded and the ones that cover the bolts that attach the cab to the chassis? If so, the ones from a 2nd gen work, at least they did on mine. I think there are three sizes though.
