will 2019 4Runner TRD Off Road suspension fit in a 2003 sport v8?
kenyansagi
Junior Member
Hey guys,
Just picked up a 2003 sport v8 with about 180k miles on it and looks like it was mostly driven on highways and did some mild towing.
My x-reas seems to be leaking in front (just a tiny bit, a drop every couple weeks) so wanted to take it out and put in something simpler.
Found 2019 4runner TRD offroad set on craigslist, will that fit my 4r?
here are the parts included:
2x front struts (48510-35440) with springs (48131-35650)
2x rear springs (48231-35340)
2x rear shocks (48530-35251)
Thanks for your help!
Yes but the rear mounting bushing must be reamed out a tiny bit I believe.
Thanks for the quick reply there [MENTION=106907]Alberta4Runner[/MENTION].
Since I'm having my mechanic do it, would it work with my stock setup if I get the front assembled strusts from 2019 TRD off-road and then use something like Bilstein 4600s or 5100s in the back? I'll also use the springs from the 2019 if it's a stock swap.
Thanks!
Hi,,,just found some used 20018 trd 4r rear Tokico shocks on CL,,,part 48530-35251 ,, will they bolt up on my 2006 4runner?????? hopefully someone can help me out....thanks!!!
Thanks!
See the X-REAS delete...” post linked in my sig. My gear came from a Tacoma but the process is similar.
NVBASSJUNKIE
