Will these fit?
socalmatthew
So I know this question is asked a lot, and I have search this site using the search bar for someone posting whether or not these wheels will fit on a 5th gen but I was only able to find people who have them on earlier gens.
Wheels in question:
https://www.amazon.com/American-Rac...d=1490592212&sr=8-2&keywords=17x8+6x139.7#Ask
I have bought some 285/70/17 Nitto Ridge Grapplers that are too wide for my stock SR5 wheels so I am looking for a slightly wider wheel to mount these tires on.
I am worried that they will rub on the brake calipers or not clear the UCA's.
Any advice or insight is appreciated, thank you!
Bolt pattern = 6 X 139.7
8 - 8.5" wide rim with 4.1 to 4.5" of Back Spacing is about ideal for a 5th gen.
Wheels in question:
http://www.toyota-4runner.org/5th-gen-t4rs/153173-5th-gen-wheel-tire-thread-8.html#post2124414
Maybe [MENTION=112177]4RnR Grl[/MENTION] could chime in with any further issues than those she addressed in the post...
:cheers:
I have BFG KO2s on this exact wheel with a lift and aftermarket UCAs. On a stock suspension, the tires will rub. With a lift, it will vary. I have slight rubbing on the body mount in reverse at full lock. Keep in mind I also have an aftermarket bumper, so I don't know where they will rub on that. The wheels fit fine and clear calipers fine. I used the fitment guide on this forum to determine this (specifically the section about backspacing). BUT.... I also have spidertrax wheel spacers (1.25) so keep that in mind as well. As long as you pay attention to the backspacing issue you should be fine. There are a lot of variables you need to consider... but the bottom line is, if you are lifted with aftermarket UCAs, the bigger tire will fit... and you MIGHT have rubbing somewhere.
I bought these wheels specifically because I knew I was going to bang them up on trails and I wasn't going to pay $300 for a wheel that was going to get beat up. They have held up well and I haven't had to replace any yet after 18 months. I also have this wheel on my spare as well under the truck.
Just omit the dumb center caps. They stick out really far and look hideous.
[MENTION=112177]4RnR Grl[/MENTION] [MENTION=151024]CRSTX[/MENTION] [MENTION=133021]propain[/MENTION] [MENTION=133649]Angelo[/MENTION]
Thank you for your responses and insights! I really appreciate it and will feel better now when I purchase the wheels.
Also I thought I might mention that, according to what I've seen on this board with regard to those two specific tires (NRG / KO2), the BFGs tend to measure a little smaller than their labeled size while the Nittos tend to be truer to size.
Good luck man. Post pics when you get 'em mounted.
Thank you again.
I will make sure to post some pics!
AndiGarage
