Window Issues
I recently installed a new clutch/brake pedal bracket in my 1995 Runner (not as bad as I anticipated). After completing this job, I've noticed that the only window I can get to operate is the drivers door window. The other 3 passenger windows will not go up or down, and the rear window will only go down at the key switch. The console switch does nothing. Also, my instrument cluster lights don't work. I'm pretty lost on this. Any suggestions?
I would check and see if you may have hit a wire when you installed the pedal bracket. Or maybe knocked out a fuse since the box is right there
044runner4
