Windows won't roll down
tortex53
It started raining here not too long ago, and I just found out today that my power windows won't roll down. (I have a '92 with power windows and power locks. The locks still work fine.) The driver's window does roll down, but none of the other 3 will. During the summer all the windows rolled down, but the back two would operate slowly. I looked for a fuse, but I couldn't find one for the windows. It just doesn't make sense that all 3 would stop working at once! But at least they are stuck up instead of being stuck down. Any advice would be greatly appreciated.
might as well check all your fuses. id check the window lock button isnt jammed/fried to 'lock'. after that id check the window motors/wiring manually
I checked the lock button, but I can't roll them down from the driver's controls either. I'll have to check all the fuses, but the fuse diagram didn't have one listed for windows. I also don't understand how all three motors could have gone out at the same time. Any other thoughts?
on my 93 when the window lock button is on i cant roll down the windows from the drivers controls either, so id make sure its not faulty. chances are all three motors didnt burn out at the same time.. and there is no designated window fuse, its tied into a combination of an always hot fuse, an ACC fuse and a On fuse. something that is all three because when the car is running then turned off (key in off) you can unroll/roll up the windows within 15 seconds or until you open a door. there is some sort of control or fuse that is linked to it. ill check my haynes for window wiring.
You mean even with the window lock button off the 3 will not go down?
When the button is on no controls work accept the drivers window button.
If the button is off and they don't go down the issue is with the window lock button.
Mike
I'd pull the door panels off and grease/clean the tracks. wont do any harm, and gives you a good look at the inside
tobasko556
