Wiper Maintenance
Thai
Elite Member
Wipers are often overlooked
by Jim Kerr
Every vehicle has them. Some have one; most have two, and there are even some with three! Wipers are an important safety feature on our vehicles but they usually only get any attention when they don't work. With spring showers on the way, your vehicle's wipers will be put to the test again. Inspecting them only takes a few seconds.
Rubber wiper blades don't last forever. After a few years, the rubber starts to tear and then you have a metal wiper arm rubbing against the windshield. Unfortunately, this usually happens when you are driving down the highway far away from any service shop and an expensive windshield gets scratched. Replace the rubber blades before problems occur. I find that after about two years of service, the rubber is starting to harden enough that wiping performance decreases. Installing new blades takes a few minutes and can be done by most owners.
The lowest cost wiper blade is typically a wiper blade "refill". This is just the rubber blade with some thin stainless reinforcement strips. The old blade insert is removed from the wiper arm by squeezing the sides together and slipping the insert out the end of the wiper arm. Installing the new refills is the opposite of removing the old ones. Wiper blades come in many different lengths so be sure to measure yours before going into the parts store.
A quicker and easier method (but more costly) way of replacing the blades is to replace the wiper blade complete with it's support mechanism. Usually the complete unit unclips from the wiper arm and can be removed in a couple seconds. There are several options when buying new units. Some come completely encased in rubber to prevent ice build-up in the pivot points. Others have wings on them so the wind will push the wiper blades down on the window glass at high speed. Some come with two blades in one, for improved clearing in heavy rain. Silicone rubber is used in some blades so they are more flexible. All work well but the most important thing to remember is that any blade needs regular replacement.
Electronics are changing the way wipers work too. Almost all vehicles now come with intermittent or pulse wipers. Capacitors inside the wiper motor charge up electrically until the voltage is high enough to trigger a transistor. The transistor turns on the wiper motor for one sweep. The driver controls the delay time or pulse rate with a knob that varies the voltage to the pulse circuit in the wiper motor. It sounds complicated but it is really a very simple electronic circuit.
Sometimes a vehicle will have a "phantom" wipe. The wiper motor makes one sweep all by itself without the driver even touching the wiper switch. Usually this problem is caused by moisture on the pulse circuit board in the wiper motor. Water is a conductor of electricity so a drop in the wrong place can cause unwanted operation. A trickle of electricity flows through the water from a power connection to a pulse input connection and the wipers turn on. Often this problem occurs after the vehicle's engine compartment has been thoroughly washed at a hand-operated car wash. Sealing the electrical connections with some silicone grease can help prevent water from entering.
Improvements to wipers aren't dramatic but do occur. Rain Sense wipers are now offered on several premium and luxury vehicles. A module near the interior rear view mirror detects the change in refraction of light as it passes through water on the windshield. The driver sets the wipers in Auto mode and forgets them. When water is sensed, the wipers turn on automatically until the windshield is clean again. This system is great when driving in a slight mist where even the slowest pulse setting is too frequent. The rain sense system only operates when there is moisture present, but be sure to remember and turn them off before entering an automatic car wash!
Finally, an Ontario inventor has designed a wiper shaker. How many times have you had the wiper blades freeze up in the winter and clear only a small part of the windshield? The wiper shaker vibrates the wiper arms and blades, causing the ice to break off the wipers. It's much easier and safer than stopping the car and clearing them by hand.
Wipers may not attract a lot of attention of new car buyers but they definitely do from automotive engineers. Some of the wind noise you hear when driving down the road comes from air turbulence as it passes over the wiper arms and blades. Vehicles such as the Lexus RX330 are much quieter because the engineers paid attention to air flow and moved the wipers slightly so much of the turbulence is eliminated.
Even the small things are important. Good visibility during even poor driving conditions is essential to safe driving so keep an eye on the small things and check those wiper blades now.
I read in a car owners guide that if you use wax at a drive through car wash, one where the wax is sprayed in a liquid form, the wipers will fatigue faster. I think it was in the 1997 Heep Grand Cherokee manual, but don't hold me 2 it.
Hmm...that wax must react more readily with ozone or something....
Anyway, I try to replace my wipers on an annual basis.
can anyone tell me how to get the wiper clip off-without breaking it? im trying to replacing the whole thing, not just the rubber. isther a pic anywhere.
'99 limited. thanks.
If you lift the wiper arm up, and pivot the wiper blade slightly away from the arm (from the inside of the cabin looking out, the end of the wiper blade near the passenger side will be further away from the windsheild and the driver side of the blade is closer to the glass). You should be able to see a small clip of the wiper blade assembly that hooks up with the wiper arm. Push the small clip towards the wiper arm and slide the wiper blade down towards the cowl (hood area). You'll need to move the arm and the wiper blade slightly to pull the arm through the wiper blade. The wiper arm end looks like a hook and locks itself on to a pivoting clip on the wiper blade.
I have a couple wiper issues and wanted to see if anyone else has had the same issues first the wiper fluid spray has stopped working, (and yes it has fluid) now the front wipers will just start going when you are going down the road.
I created a new thread where you should get some help here.
