Wiring route question: adding Goal Zero Yeti Link kit
Bonesetter
Hey everyone, I'm wondering if anyone has added the GZ Yeti Link kit to their rig, and if so how did you end up running the cables? They're large (6awg) with large attachments on the ends, so going through the engine firewall seems to be a no-go. I could run along the frame underneath, but then I'm not sure how to route the cable into the cargo compartment. Any thoughts or suggestions are, as always, welcome for this one-leaf shade tree mechanic. Thanks!
Link provided for reference.
Yeti Link Vehicle Integration Kit V3
– Goal Zero
if you know how to remove the anderson plugs, that will make passing one end of the cable smaller at the passenger side firewall grommet, but if you don't want to do that, you can run is through your frame rail to the cargo area, there is grommet on the cargo floor when you lift the carpet up. cut a slit and silicone is back up so you have water come in.
as long your cable is long enough. or make your own wiring.
Bunkstaff
