Would these wheels fit on a 2008 4Runner w/o a lift?
wheels might fit, if there are not bigger than 25mm offset, but the tires will rub, for 22's use 285/40 r22 tires.
With the wheels, you need to know the centerbore. Toyota has a larger center and if these wheels were built to fit a GM then the center wil be too small. That is way too large a setup for a 4Runner. The wheels are available at discount tire for $160 with a $50 rebate off a set of 4.
tires DEF wont fit without a 4" lift. And rarely do wheel companies these days build wheels to the exact GM size. Theyre built to be larger and people use hub centric rings to bring it down size.
allcarhistory
