Write-up: How to Disable (Bypass) the TPMS
So looking at doing this for my 06 SR5, but not looking to buy 100 scotchloks...does anyone know where to get just a couple? And the Blue colored ones worked best for most people?
Advance Auto should carry em. They go by a different name though. "Splice Connector" iirc. I used the red ones, blue may work as well
Worked for me
Just did this to my 2006 SR5 v8 4wd. Easiest mod ever! Jumpered the Pink-Black to the White black as in the photograph on the original post. I skipped the slice thingy and just used short bit of telco wire pressed in the back of the white connector for the two target pins. No more blinking light.
I just did this mod today. I used a small blue scotchlok connector.
The agonizing over it all was wayyyyyyy more than the mod itself.
However, now the "MAINT" light blinks 6 times every time I start her.
When I bought her she had 110k and now has 111.5k.
Could be a coincidence of the maintenance computer not being reset but no "MAINT" light till I did this mod.
Any thoughts or experience with this
Fml. Tried this today, the light only flashed off once, and is still shining it's ugly face at me. I used the blue schlock connector, I'll try the red one this weekend. I will report back.
As everyone said, great write up. The longest part of this was cutting the tape! One less nanny feature. I have an 06, btw
wire jumper-ed
I pulled the connector and jumper-ed the two wires through the pin connector. Is there any benefits in doing one way or the other? Is there other items connected through this module that I have to be concerned about? Easies mod ever. Thanks all
No Light!
Been subscribed to this thread forever thinknig at some point the TPMS battery(s) would fail or in my case a slow leak in the valve stem area. It's a 04 Limited that spent the first 6 years in Ohio and now the last in MD. The rims were beat.
So I made a trip to Tirerack in DE and picked up new shoes. Just swapped the 4, kept the spare in place.
No blinking light! It was on a few weeks ago after the 4runner sat for 2 weeks while on vacation so I know the TPMS was working then.
Drove 40miles to work this am and no light. Not sure why.
CEH in MD
04 V8 Limited with 230,000 miles
CEH in MD
Check the pressure on the new tires. It might've dropped a few weeks ago when it got colder outside, then the shop pumped the new tires up and TPMS was happy again.
Just to be clear the new rims do not have sensors. Oem rims are in the shed except for the spare.
Sent from my SM-G928V using Tapatalk
I've seen this happen before. If your shed is close by your 4Runner, then you must still have proper PSI in your old tires. Because once your 4Runner is close enough to your old sensors and registers them at 0 or low psi the light will turn on. I've gotten away with this for a few weeks until all of a sudden the light turned on again.
I confess I haven't read this whole thread, but I am curious as to how this TPMS works. I was under the impression that it worked off of wheel speed, when the ECM detected one or more wheels not up to the speed of the others, indicating lower pressure than the others (the reason the button must be reset, at least in my wife's '07 Sienna. I don't mind the sensor so much, but it seems with a few more lines of code it can tell which tire is lower.
CoaterZ_FL
