4Runner alternator upgrade (gen 5)
I'm not Rigtec,...
'That's right!'
I have no idea why you're answering "Mentions" addressed to me, and attempt to hack two of my Original (works) threads simultaneously! You need to find something else to do...
PS: The Moderators/admin. have been notified about your conduct on these forums and are watchfully looking into this disruptive behavior. I'm trying to be politely for the sake of the other community members here...
[MENTION=83083]rigtec[/MENTION] - awesome post, thank you.
I bought the same cigarette lighter battery/alternator gauge after reading your post.
Un-related to 4runner, the gauge shows the battery in my daily driver is weak (11.6V after sitting in garage overnight at ~40degF). Charging system seems good, gauge reads 14.2V with green light at full electrical load above 1500RPM..."
Hi como_engineer,
No, I don't see anything unusual about the numbers; 11.6V is ideal, given that your 'ECU compu network/clock' draws current to keep processing when the vehicle is not in use! Your alternator is also performing as it should @14.2 immediately after starting, and should decrease to about 13.6V once it gets hot and the battery is fully charged! ...Ride with confidence bro! :car:
'Best to you'
'That's right!'
Rig - I clearly disclaimed I was not posting as you - and I don't believe there are any forum rules about answering inquiries even if they are "Mentioned" towards another member. As you likely do, I am alerted of forum replies via email, saw the inquiry in the email, and knew it was a question I could answer immediately (so I did).
As to my "disruptive" behavior - I am submitting evidence that my claims you politely called out as "silly" are indeed factual. And like mentioned (and hopefully comprehended) - suggesting that polarity is of no consequence above 200Hz in a vehicle (and suggesting the 6x9"s in the door will not see any information below 200Hz) is reckless to an unsuspecting DIY Audio Dude. If correcting erroneous and possibly misleading information posted on this public webforum is against forum rules, then I'd better get outta here pretty quick :) (or the Mods can ban me to expedite that process of squashing fact-checking!)
Interestingly - No replies to my rebuttals to your claim of my "silly conversation" about alternator workings and absolute polarity considerations that are rooted in 20+ years of real-world experience with high-current mobile and high-end professional audio systems.
Battery resting at 11.6V after an overnight sit seems low to me (far from your claim of "Ideal" to be bluntly honest). If you let it sit for a week - it would most certainly be dead by then if your assumption of idle current draw being high enough to bring a battery down to 11.6v in a ~10 hour timespan is correct.
I'm of the opinion the battery is on the way out - and that is the reason for the low resting voltage (low by my observation, not yours). I would highly suggest getting the battery tested (for free) to rule out any issues as not to have one of our fellow forum members stranded with a dead battery in a vehicle with an automatic transmission (no push-starts available).
Somehow, I don't believe the Mods are seeing me as someone to ban. If they are - then I guess real-world results and decade-spanning-observations should also be banned (at least the ones I make :) )...
:cool:
Any follow up info [MENTION=83083]rigtec[/MENTION] ? I have my group 31 battery coming and am contemplating this mod to keep my battery happy
Hi Adam,
You know... I've done quite a few electrical upgrades to this 2012 limited 4Runner over the last four years since I ordered it, but looking back, I can honestly tell you that this was 'for sure', the best planned, most well invested cash that I've thrown at the truck since I'd gotten it! I was also very pleased to learn that a few others here have done the same; 270XP alternator swap, BIG THREE power grid upgrade... and their report was quite favorable as well!
And the battery that I bought was an Odyssdey EXTREME AGM 27f (900 CCA); not quite as large as yours but cranking in the winter sounded to me just as they do in the summer... strong and fast w/o even the slightest hint of lag! The Alternator upgrade and big three both went in without a hitch! Buy with Confidence!
...and 'Best to you'!
Thanks for the feedback. I am lining up funds for this project. I eventually want to install amps and new speakers and want no issues. Your schematic makes this a snap. Thanks again
Just placed my order for 270xp and big three upgrade. Will post install pics when they arrive.
WOW Adam,
Kudos! I know you'll be extremely satisfied with the 270XP! One of the best things that I love about these alternators is it'll do 200A at curb-side idle; that's more than our stock unit was designed to develop completely loaded up (full-fielded)! The 270xp has been in for about two years now and I've never had an issue or even a question about it's performance... it still maintains 14V at all times (cruising or idling); even when hot and the truck's accessories are most all being used simultaneously!
'tis one of my best investments, Regards!
I gotta admit - a stout +14.4VDC does sound very tempting :) I'm lucky to hit 13.4V steadily with the stock alt.
I'd actually be happy if I could get the stocker to produce that voltage (130Amps of steady current is actually plenty for my dynamic current-draw needs - but the extra voltage is desired for AGM batteries and a better situation for most mobile electronics) - but I realize that is a feeble battle :(
Rock on, Rigtec! :tea:
Hey folks,
I found this document on the DC Power Engineering website and thought you might be interested to read it; since most of us are pushing our electrical systems beyond, or to the limits of what they were designed to do... thought I'd post it here for anyone to view:
This is my alternator pictured below:
"THE TRUTH ABOUT IDLE"
DC Power Engineering - The Truth About Idle
Purchasing a high-output alternator can be a very tedious and mind-boggling experience if you don’t know what to look for or at least know the important questions to ask. At DC Power, we have nothing to hide as our alternators meet or exceed our customers’ expectations every time. The main reason for that is because we design, engineer, and manufacture our units to get the results we desire – the results our customers demand!
But . . . I Got a Smokin’ Deal!
A good portion of our business is with customers who have already purchased an alternator from another company only to find out that it didn’t do what was claimed or worse yet, it didn’t meet their requirements. This is an excellent example where the bargain price will actually cost you more money in the long run – in some cases, a lot more. Don’t fall into this trap. Choosing the correct unit for your application will make the difference between excellent reliability and a healthy electrical system OR short life span and / or damage to your vehicle’s electrical system.
Idle Output
Last we checked, you don’t normally cruise around town at 4,000 RPM. Rather, in town driving is stop and go, so your vehicle sees a lot of time at idle. When you’re rolling down the highway in overdrive, it’s not uncommon for engine RPM to be between 1,800 and 2,200 RPM. These are considered normal driving conditions so you absolutely want a high-output alternator that has been designed to work well under these conditions. Choose poorly and you’ll have serious problems, including: poor engine idling characteristics; dimming lights; an inadequate supply of voltage to the various on-board computers and modules; a weak or even dead battery; and possibly even engine stalling.
Since we at DC Power feel so strongly about this specification, we provide it on every unit that we sell. If you’re shopping around, we’ll provide the following questions that you should ask in rank of importance so that you can compare apples to apples. Now . . . who else does that?
What is the alternator’s output at idle?
Without question, the most important consideration when purchasing a high-output alternator is its output capability when the engine is idling. This is especially true with modern vehicles as they have extremely high electrical demands from on-board computers, safety equipment, convenience modules, and accessories – to the point that many require at least 120 amps at idle. Yes, that’s a bunch!
All DC Power alternators are designed to produce the highest output possible at idle. For example, our 270 amp XP Series Corvette unit can deliver 200 amps at idle – this is 130 more than the stock unit! Most of our alternators produce in excess of 50% of their rated maximum output at idle, some up to 70%. This becomes increasingly important with the addition of current hungry aftermarket accessories such as high powered lighting, AC inverters, high performance car stereo systems, etc. The addition of such accessories is more than likely why you’re considering the purchase of a high-output alternator in the first place.
What idle speed are you basing your idle output rating on?
When we speak of idling, your engine probably idles somewhere between 700 and 900 RPM. Your alternator is driven by the belt, which connects its pulley to the pulley at the front of the crankshaft. Because the pulley on your alternator is quite a bit smaller in diameter than the one on the crankshaft, it spins at a much higher RPM than the engine does. So, when we say “idle speed” we are referring to the actual RPM of the alternator itself with the engine idling, not the engine.
Idle speed is idle speed right? Well, not exactly. For many years, the industry standard was 2,500 RPM and there was a time when this was accurate. Not any more. With today’s modern vehicles and emission standards, alternator idle speeds are MUCH lower – now typically between 1600 and 1900 RPM. Despite this change, you will find that some companies are still using this over-inflated idle speed when calculating the idle output of their alternators.
The idle output rating of every DC Power Alternator is given based on the actual idle RPM of the vehicle the alternator is intended for – not a typical or “universal” idle speed. Furthermore, our units are capable of meeting this specification at operating temperature – not when ice cold! These two differences set us apart from the pack.
How do you determine the alternators’ speed at idle?
By now, you may have hung the phone up on the other guys anyway. BUT, if you’ve gotten this far we’ll tell you that we don’t really know how our competitors determine idle speed – obviously a critical component in answering the first two questions.
At DC Power, we use the following method:
1. Test
2. Analyze
3. Re-test
4. Measure
5. Re-analyze
6. Confirm the results by testing, measuring, and analyzing again . . .
We use an optical laser tachometer to get the exact idle speed of each vehicle that we offer an alternator for and keep this info in a giant database. We perform extensive on-car load testing on our alternators to be absolutely certain that they will deliver what we claim. Finally, we conduct extensive bench testing (hyperlink to testing page) to every single one that we offer. Every alternator we offer has gone through this rigorous process to ensure that it works as advertised and meets or exceeds your expectations.
No other brand of alternator will outperform a properly installed DC Power alternator!
logo.png~original
"GETTING YOUR VEHICLE THE POWER IT NEEDS"
Getting your vehicle the power it needs.
There are a few different options available when it comes making a decision about equipping your vehicle with the power it needs to function properly and meet the demands of added electronic equipment. While we will be explaining the different options available, we at DC Power Engineering only view one of them as the proper solution. That is option number three, we put it last so that you have the chance to view all options so that you can make the most informed and educated decision possible.
Option one
Your first option is simply to do nothing and ignore the problem. The upside, there is no real upside. The downside, you may experience all or some of the symptoms covered in the Supply and Demand article. Your alternator fails prematurely due to being over worked. The worst-case scenario is that your alternator fails as a result of overworking it. Your accessories quit working, the on board computer system fails, and if you are driving and your alternator quits, pretty soon your sitting on the side of the road, waiting for a tow truck and an expensive bill you don’t want or need! If your alternator is not charging your battery, essentially your vehicle is on borrowed time, using only the juice in the battery to keep it self running. Once it is gone your vehicle shuts down immediately with no warning, including your vehicles computer system. Think about all the electronics in your house, primarily your LCD TV, home computer system, appliances etc, central air conditioning, all the comforts of home. Now imagine that the power company comes along and shuts off the power to your house at the main breaker, you lose it ALL! This is basically what happens when your alternator stops working.
When that power comes back on they recommend that all electronic equipment and computers are disconnected from the wall because the sudden surge of power coming back into the house has the ability short them out. Now, back to the example your car or truck, the same thing happens when the battery is reconnected or you try to jump-start your dead battery. This can be a very dangerous situation and damage the sensitive electronics found in today’s modern vehicles.
Option two
Your second option is to have the alternator rewound by somebody for higher output to get you the adequate output for your needs. The upside - You have found someone to rewind your alternator and claims that it is rated at 200, 250 amps and 150 amps at idle, or whatever works for the needs of your vehicle. This can be a good solution as long as you find someone who is capable of doing it correctly, and assuming they know how get alternators that perform as they should. So, you get your re-wrapped, or rewound alternator done, you saved some money, and you get it put back in your car. Wait a minute, why are my lights dim and my battery voltage is low? This is when you usually find out that the money you just spent getting a “better” alternator, is actually worse! You find out now at idle your alternator is only producing 40 or 50 amps or even worse, not charging at all! Now you have a potentially serious problem because that much output is not even enough to maintain your vehicles most basic charging system needs and you are at big risk of serious problems! And, if you are only having your alternator rewound for higher output, they could still be re-using the other used components such as the voltage regulator and rectifier, which have also experienced untold miles of wear and tear! This can cause the rewound alternator to not perform as well or last as long as expected and those parts might not even have a warranty.
Option three is to purchase a new high performance, high quality alternator or add a second alternator [link to running two alternators article] to your vehicle. This is generally the best, most viable option that we view as a real solution to repair the needs of your charging system. The upside – Everything works as advertised, you have all the extra power you need for all of the standard accessories and vehicle systems, as well as all of the extra accessories and electronic components. You will have enough extra power for all the vehicles systems to function properly and safely. And as an added bonus your electronic equipment will not fail prematurely from a lack of power, which can save you big bucks in the end. The only real downside is a little larger investment upfront. Buying a high quality high output alternator may cost you more than option one or two up front, but it is worth every dime in the end.
XP and HP Series High Output Alternator Information
Generating Power Where it Matters Most – At "TRUE" Idle.
DC Power’s 180-HP, 230-XP, 250-XP and 270-XP high output alternators do more than 70 percent of their maximum rated output at idle. Due to the efficiency of the alternators stator configuration they will lose less output when hot. So for example you can expect our 270XP to continually do 160+ amps at idle right next to exhaust headers that easily reach over 200 degrees Fahrenheit without having any cooling issues. For more information about how important alternator idle performance is, please visit our tech article The Truth about “Idle”
Reducing Size and Electrical Noise with DENSO’s new Hairpin Stator
By using a welded, rectangular copper stator, DC Power Engineering has been able to increase the winding density up to 70 percent versus 45 percent seen in a typical inferior stator design. By increasing the winding density allowed the weight to be reduced by 20 percent, increased power output by 50 percent while increasing generation efficiency by 10 percent. The efficiency in the stator design reduces electromagnetic noise by 10 decibels. By engineering a newly designed noise cancellation circuit by dividing the alternator’s stator coil into two separate pairs that produce a phase difference. This allows the alternator’s AC ripple current to decreased by 700 percent, which eliminates engine noise generated by the alternator for noise sensitive electronics.
Stator for XP and HP High Output Alternators
conventional-cross-section.png~original
Increasing Surface Area for Cooling
To solve the problem of higher heat production due to higher output, the rectifiers use 12 50-amp press-fit diodes. The surface area of the rectifier cooling fins to nearly twice the size of conventional fins, improving the cooling ability of the rectifiers. This allows vehicles that typically run larger, single water-cooled alternator or two air-cooled alternators to be replaced with a single air-cooled alternator while providing the same output with more reliability and efficiency.
DC Power Engineering’s Exclusive DENSO Partnership
Due to DENSO's high output alternator technological advances in the rotating electrical industry, DC Power Engineering has partnered with DENSO to bring their new technology to the aftermarket with DC Power Engineering's own proprietary part numbers. With DC Power Engineering's in house R&D Team, HAAS ST-30 Lathe and HAAS VM-2 CNC Machines and Mastercam X5, we are able to create direct drop in replacements for thousands of different vehicle applications. Whether you have a Chevrolet, Ford, GMC, Honda, Toyota, Dodge, Cadillac, Nissan, Acura, Jeep, Mazda, Pontiac, Buick, Volkswagen, or another manufacture chances are, DC Power Engineering may have a solution!
Durability
Our XP and HP Series alternators are manufactured in the USA. DC Power Engineering uses OEM (Original Equipment Manufacturer) components for maximum life and is backed by our 2-year warranty.
"There are a few people asking about the 270-XP H.O. alternator and I found this documentation about it so I couldn't pass it up. Another question that I've been asked was about 'DC Power Engineering' and their fitment guide; it only goes up to the 2009 4Runner and no further... I asked them that same question when ordering mine and their answer was: "Our fitment guide is just a little out of date" ...I mean comm'on guys... I bought my 270-xp alternator two years ago and you mean you couldn't fix that catalog problem in two years... Anyway the model number is:
DC Power Engineering (M) 270-XP Product code: 101362 This is the one that's on my truck so that should be the same # for yours as well.
Their phone# is Toll Free (US ONLY): 888-441-0144"
I hope someone here will find this helpful at some point should you decide to go that route! "Best to you all!"
rig
Hey again techies,
Just the other day I had a request for help by [MENTION=133836]adam.friedman.33[/MENTION] who was beyond interested in purchasing the DC Power Engineering 270XP H.O. alternator, he had attempted to place his order, only to be met with a bunch of confusion from the c/s person that he'd spoken with. Well, just a few minutes ago I called Nations starter and Alternator; the distributor for the company and explained the situation to her (this lady, Holly, was the greatest help!). I gave her my original sales w/o number, but some how that didn't help her distinguish the gen-4, from the gen-5 4Runner.
It seems that somehow there's been a missing link (paper trail breach) to my purchase so she told me that, that sales number shows her that this alternator will fit the 2011 taco, but was unsure if it translated to the gen-5 4Runner. She then spoke to the owner; who in my opinion is the greatest help that you could get as well. In 60 seconds, he gave her the model# to the 270-XP alternator that I bought two years ago... for those who have wanted to order one the model # is: NSA-11517-270XP. This alternator IS the one that will fit your gen-5 4Runner!
Nations starter & alternator's phone# is: 573-334-2632 You can speak to Holly or Adam and you'll be very satisfied with the way they handle your order, and the performance of their products! Here's a sample video of their approach to their fine products: https://www.youtube.com/watch?v=8zfqZjoYsRQ&feature=youtu.be "Be blessed folks"!
Cheers
Oh...
I neglected to mention one important detail about the 270-XP. You can order yours with an 'adjustable external voltage regulator'; but this has to be done at the manufacturer's facility, not a 'plug-&-play' add-on! My internal regulator is set @14V which is what I've wanted; especially with the "Odyssey extreme" AGM 900 CCA, 125 min res battery! But some here may have concerns about battery life span, or having ECU issues (which shouldn't be a concern because the alternator is ecu compliant/compatible)...and mine has been in for two years w/o issue! Rgds!
Thanks to [MENTION=83083]rigtec[/MENTION] my 270xp will be here in two days! He went above and beyond helping me out to ensure I got exactly the right alternator and even called a vendor on my behalf. I owe you a solid brother! Thanks again
Thanks Adam,
...But no favors asked except to keep us posted when you do receive your 270! The c/s person 'Holly' told me that they are now stocking the NSA-11517-270XP because of our communication (T4R.org) with them and the time we spent to explain to them the problem that they had with their fitment catalog; only going up to the 2009 4Runner. Apparently they weren't aware of the problem so they're going to make some changes because of our huge forum community... perhaps in the future, we can work-out a 'Group buy' of some sort; as a matter of fact I know we can if enough of us show an interest in ordering them.
I seem to have struck up a "friendship" with them because I spoke so highly of them and their products while on the phone earlier today(I've been extremely satisfied with mine over the last two years), so... who knows! I'm so glad things worked out so well for you [MENTION=133836]adam.friedman.33[/MENTION] . I had to wait about seven weeks for them to build mine cuz they're made to order; or they were before now lol!
Cheers!
For some reason I have two user id's in tapatalk. The incorrect one is adam.friedman the correct is smkymntn. I tried to have one shop install alternator and they were clueless as I Im'd you about. Have another shop doing install today. Hopefully they are more adept and able to complete. I settled on a 1000w Jl audio amp and all JL speakers for stereo install. Going to take some time off and do install next week. Have been planning for weeks. Will post pics.
Hi Adam,
You're doing things the The RIGHT way! Myself (OTOH) discovered that I needed a generator upgrade after seeing the symptoms of an alternator that just couldn't keep up e.g. headlight pulsation, temperature control blower and wiper motors slowing down...etc. I'm very much looking fwd to seeing (reading about) your finished product!
Because you're adding approximately 100A to your existing main electrical system cables, I would strongly recommend adding an additional (POS) Alternator output (B+ term) to positive battery terminal post and (NEG) battery cables; main negative battery post to body, and an engine to body cable:
rigtec-albums-%26quot%3Bgentilmen+prefer+redheads%26quot%3B-picture26784-all-cell-pix-june-2014-012.jpg
The dotted lines represent the existing factory cables, which I've left in place. The solid lines illustrate the new, heavier 4ga cables that were installed.
Don't worry about the body to frame (chassis) cable; there will be no additional or excessive loads added to that circuit!
'Best to you'!
H.Sikina
