Factory Tundra LED Fog Lights in 5th Gen 4Runner
I just replaced the stock bulbs with a a pair of Phillips X-tremeVision LED bulbs. Huge difference over the stock halogen bulbs and no modding needed. They are good enough that I wouldn't change anything unless I was going to switch to Rigid or Baja Design LED assemblies.
I didn't go this route because I hate when I'm driving at night and get blinded by other people's lights. It's usually because an LED or HID bulb is installed in the wrong housing. I didn't want to blind other people so I could have a cheaper/easier/whatever way of "upgrading."
I was also gonna roll with the Philips Xtreme Vision LEDs in the fogs but not this got me interested. I like the fact that its an OEM part. I wonder how many lumens this is compared to the Philips LEDs?
So will these fit any 5th gen?
I have a 2017 and they were a direct fit. Fit exactly into the mounting tabs and the screw holes lined up exactly. Even the cover on the passenger side fit back over the assembly.
What is the connection like? Does it just snap into the existing H16 connector???
They were plug and play with the stock harness and connector.
I can't speak for the lumen comparison. I read through a few of the Tundra forum posts and found good info on Youtube - https://www.youtube.com/watch?v=cfYfwpGP9LM
Left Side
Right Side
You may want to Google "Toyota Parts Dealer near XXX." Cool Springs sold the assemblies cheaper than my local dealer and with shipping it was still a few bucks under. Only problem is I had to wait a few days for delivery.
Also, the phillips screws that come out of your old assembly will mount the new so need to purchase more.
I'll post some night pics soon. I'm in college on nights and weekends so busy for me. As for the adjustment, I did need to adjust the beams up/down to be level with each other. Do a form search or youtube search for aiming lights. It's simple.
Appreciate the information, bought my daughter a 2018 ORP labor day weekend and the lighting kind of sucks. I was going to go the Morimoto route and am glad I found your post, I too prefer OEM. Did the swap today, and did both sides from under the front, too lazy to put her on a stand, didn't take off the wheels either.
It helped a lot once I got a good look at the passenger shield and noted the clip points. The only thing I am kicking myself is that I did the same on my 2012 IS-F (Lexus started to replace the halogen w/ LED in 2013), and when I sold the IS-F last May, I didn't bother to swap the fogs out. Could have saved another 2 bills (same P/N's).
Thanks for the post again.
Big question -- was there any need to adjust the lights or was it good to go out of the box?
How do you remove the lights from the rear -- on my limited there are shields over both the light fixtures -- do those come off???
Todd
Woo-hoo
Just finished putting mine in.
This is so easy why can't toyota do this at the factory???
All you have to do is remove the white clip at the top of the light cover, and remove the screw at the left of the light (driver side, reverse for passenger)
That chrome piece will push out, be careful and don't go to far. You should be able to get it out enough to remove the two screws holding in the old fog light and pull out the old light and swap in the new one.
Then careful pushing it back into place and make sure all the tabs go in and seat. Put the white tab back in and screw, attach the plug and VOILA, LED fog lights from the factory that look great.
Looks like the aim was on too right out of the box.
Wish I had done this first thing rather than try and find an upgrade for an H16 bulb.
I just installed these. What a pain!! I had to go through the wheel well, loosen the fender liners, remove plastic pins, a screw and unhook the fog lights, then open the hood, remove the radiator cover, reach inside to remove the other pins that hold the fog light housing in place. Once the housing was out it took 3 minutes to install the LED fogs. The beam matched perfectly with the halogen beams so I didn't have to re-aim them. I'll see how they look at night with my Morimoto 2Stroke 2.0 low beams. The whole project took 3 hours. What an awful design. I tried to take photos of the whole process but it was such a tight area that I wasn't able to. The only one I took was of the front bumper after the fog light housing was removed.
These are purely an "upgrade" just for the sake of having LEDs. 1) I am upgrading the headlights to 5500K and these pair well. 2) These are not a performance offroad light. They are a nice and easy upgrade if you're looking for white light and don't want/need the super bright and wide beam pattern of aftermarket lights. I'm not knocking the other applications. This works for how I currently use my vehicle.
What headlight bulbs are you running? In the night pictures you posted, it looks like you're running something besides stock halogens.
I know the 2019 4Runners will have an option for LED fog lights from the factory. I am impatient and also wondered if the 2018 Tundra LED fog lights would fit in the 5th generation 4Runner. The answer is YES. They are a direct fit and plug right in for my 2017 Off Road.
I prefer using factory parts as often as possible since I'm not doing any heavy duty offroading. I like the look of factory and the fact there is typically minimal (if any) modification needed.
I purchased the parts from an online Toyota parts dealer. I shopped around a bit to find good pricing and the cheapest shipping.
Part numbers:
Left assembly 81220-48051
Right assembly 81210-48051
Installation was extremely easy and the results are exactly what I wanted. Now I'll have to upgrade my headlights so the lighting is better and the color temperatures are similar.
Pictures to follow.
Do they come as a pair or do you have to order them separately?
The ones OP quoted come individually as left or right and those are made in Japan. Looks like Toyota released some that come in a paand are made in China, search for PT41342191, these are the ones with black bezel and there is a different P/N (PT413-42190) for the chrome bezel ones. According to Toyota's part page, these fit 2019 4R's, not sure if the mounting is different in the 2019 as compared to previous 5th Gen's.
BTW, the China made pairs are ~ half the cost of the 2 individual ones together.
If I order the individual left and right that OP has provided the part numbers for, do I need anything else (screws, covers, etc.)?
erinobr2000
