Wheel spacers on CL.... yes ive done me search
shootmymime
yes ive done my* search...
so i found some wheel spacers in CL for sale. the owner was going to put them on his chevy but is going with some wheeels instead. the bought them from a guy who used them for about a year on his newer model tundra. he cant find any numbers on them to give me an idea of who made them.
(worries me) but let me know if i should pull the trigger tomorrow?
1.5" wheel spacers
Those are similar to the TrailGear models, and could very well be.
Also keep in mind these are only LUG centric, whereas they should be both hub and lug centric.
I ran them in the rear with no issue, but when I had them up front they vibrated, and I didn't like it. So I switched to Spidertrax, which are superior in construction.
how can u tell they they are lug? he thought they were hub. i thought we need hub not lug tho? or do we need both? im planning on using them on a 2000 limited stock suspension to stick the tires out some
to me it looks like the lip for the hub is there, but it could just be the picture and my tiny 12" screen on my laptop.
yes there is a 1/4 lip where the lugs/nuts are. thats the hub C correct? and the lug C is the chamfered edge on the lugs?
will these work? if not is the price cheep enough to resell?
Crap, should have looked at the second picture...:dizzy:
Yea so they are hub lug centric, go ahead and get them. That is a good price, and if you have any issue you could always resell
1.5" wheel spacers
These look alot like my Allpro 2" Hub centric spacers. I bet you will have no problem. I use mine on my lifted 2000 Limited
Yeah. They are hub centric. They also look somewhat identical to my 1.5" wheel spacers.
I would pull the trigger. You might want acorn style lug nuts to mount them to your studs.
so i ended up buying them. if they worked on a big heavy tundra i think they will work for my little truck. ive got 265/75/16 tires? any chance it will rub on the back wheel well? its already about 3/8 an inch away from the bolt holding the flare on.
E32925D0-DBCA-44F0-A095-ACD96E7E406C-8215-00000794C98F3A37_zps2e3a6935.jpg~original
129D1C7F-4A1B-4536-8E44-C04E68E4D7AE-8215-00000794C802DBE0_zpse1e65b36.jpg~original
94CAF2BA-4D56-488C-B1AB-4732258AD56E-8215-00000794C6FF27D3_zps8ce7bf15.jpg~original
Take a wire brush to those bad boys and remove any rust buildup.
Ok so update time:
Im home for a week (left my 4runner in salt lake airport) and i installed these spacers on my moms 03 limited with stock tire size. now that these spacers are on they come super close to rubbing the wheel wells (front bumper and rear wheel well while turning- Front wheels only of course)
well my problem with my thinking is that when i put them on my 00 limited they will hard core rub because i already have huge tires on mine that are already .5 inches away from rubbing. So it looks like i will have to be doing some cutting and trimming when i want to install them this summer.
Not looking forward to this. might just end up selling them here if i plan to pass.
a raise of hands would any one want them for $120?
Crookedcat
