Cheapest way to mount a front-mount winch?
ShooterMcGavin
I'd like to eventually get a nice bumper, when finances are better. Without spending $600-900+ on some of the sweet bumpers out there, is there a cheap way to get a winch installed onto the front of our trucks?
probably cheaper to find a used bumper.
there are also just winch mounts. not sure what they cost tho.
If you have a fat-lip bumper, just mount the winch behind the stock bumper on a winch plate welded to the frame rails. clean and cheap
I have the same winch as you. I clocked my engagement clutch forward so I could access it more easily.
IMAG0077_zps00ee5a2b.jpg~original
You don't even need a fat lip bumper to mount the winch. [MENTION=85167]jmildoc[/MENTION] mounted his on that same plate on his 98 Limited....Looks just as nice.
Or if you don't have a fat lip bumper you could just extend the frame rails 3in and bolt on a winch plate like this. But then you are kind of screwed over on mounting an aftermarket bumper
Bryanb & singtoe, what winch plate did you use? And where did you mount the box?
:edit: looks like Bryan's is a harbor freight plate?
Did you just butt weld to the end of the rails? I'd be very afraid to stand within 100 yards when winching off that.
:couch2:
:couch2:
Negative. There is tubing sleeved and welded on the inside. You can see just a little of it in the first pic. There is also 3/16x1.5x2.5 scab plate welded on the outside the rails (not pictured):tea:
I guess I should have been a little more detailed in my posting.
