LED Blinkers
01sr54x4
If I replace (at least) my front turn signal bulbs with LEDs (which run at lower voltage) will they hyper-flash? Has anyone replaced these and experienced this? I hope not! Don't want to replace flashers or install resistors if I don't have to...
yes they will, and i have a full kit to fix that. i tried to sell it a while ago but no hits.
the easiest way i found out was to replace the flasher unit under the dash.
in that kit i have a new flasher, front and rear led bulbs
ya most led bulbs arent really that bright id go with the led flasher i got one for like 15 bucks was plug and play
Hey do you know if those LED plug n play units will fit relatively easily into the stock blinker spots, bout to go all LED
the only reason i went with a flasher unit instead of resistors is because i could always revert it back to stock if i wanted too. with resistors you would have to cut them out of your wiring harness
I was going to do LED for front and back turns too, but was afraid of having the issue you were talking about. So I ended up buying silverstar bulbs for the front and back and they were really bright compared to stock. and cheap too $20 for front turns and rear.
all the led bulbs ive had fit in the stock spots just fine changing the flasher to a led one is super easy i used a Trico EP 35 make sure it says led on it
wwarren702
