My 4th gen build
A few weeks ago I installed my new suspension. I removed the 181K mile XREAS with daystar lift and put in my 5100's with MOOG FJ coils. Also installed 2017 4runner UCA's that were taken off after around 1000 miles The ride is sooooo much better!
live9vt30f-jpg.14063
Crappy picture of the front of the rig after install.
livedqrh5b-jpg.14178
I also picked up some 5th gen SR5 wheels and bed lined them. They'll be getting installed with some 285's this winter.:becky:
liveyygaav-jpg.14070
Next up:
RCI sliders before our trip to Colorado next year!
Nice ride. What did you gain by adding the 5th gen UCA's? Just newer parts or are they different than the 4th gens?
Next up:
Looks great!! What do you have the 5100's set at? 1.75? 2.5?
So I found my drivers side caliper was sticking. I went back to O'reillys and picked up a new caliper and rotor. I already had pads from my last stuck caliper on the passenger side so those got installed as well. Saturday night in the garage...:beer:
livehntrhp-jpg.14221
All finished and bled.
liveybublp-jpg.14222
Next up:
did you have a problem with the rear springs? like it dont seat all the way down on the axle perch.
Next up:
Would you happen to know if the lower control arms also swap right over to our 4th gens? I'm seriously considering doing the uppers and lowers rather than replacing bushings and ball joints with aftermarket...
Seems like they should both be a direct bolt on to me, but that could be my optimism getting in the way...
I can't tell you 100% if the lowers will work.:confused: I CAN tell you though that the uppers bolt up no problem!
Went to 4 Wheel Parts today in Brooklyn Park, MN and picked up an on board air system and a Smittybilt tire deflator that was on sale. I'll be getting a Slee Offroad compressor mount this winter and installing it this spring since we get pretty cold up here in the winter. I don't want to damage the compressor by getting it so freakin' cold!
Next summer can't come soon enough. We are going to try some Colorado trails!:bounce:
livecbhugm-jpg.14238
Thats a good looking rig!
Do you have any rubbing, or have to do any cutting of the fender liner for your tires? I see you took the mud flaps off
