5th gen aftermarket exhaust?
I see the one video on yuotube of a 5th gen with the borla exhaust. Is there any out there of inside, under throttle?
I was hesitant to put exhaust on a 6 cylinder, but I figured a 4.0 had enough displacement to sneak by. I was right, it's not ricey sounding and actually has a nice growl when you get on it. More importantly it's not real loud, I didn't get it for sound I wanted to sneak closer to the 300hp line. Borla claims a 5-15% increase and I would say for this application it falls in the middle. No regrets and happy I went with a pre engineered full cat back from people that have been doing it for a long time. Putting a performance air filter on is a must do in letting the 4.0 breath better on both ends.
If/When you get a chance, could you measure the canister length/width/height? I had a borla canister put in, and honestly, I think it was too small for the application. Sounded like garbage and finally took it off.
Still want a little bit of a growl, but not a misfiring chainsaw like I had going.
if/when you get a chance, could you measure the canister length/width/height? I had a borla canister put in, and honestly, i think it was too small for the application. Sounded like garbage and finally took it off.
Still want a little bit of a growl, but not a misfiring chainsaw like i had going.
l 2'
w 10"
h 5.5"
You guys are looking for flowmaster super 70ii ! Same canister size as oem & very healthy for a V6 . Don't get me wrong borla makes nice stuff but better on V8 . Very happy with mine & have on both 4r !
^^^x2, love mine. Hardest part of install was unbolting factory tail pipe, those two bolts are real buggers to get out. Ended up using a cut-off wheel to cut nuts off. Other than that, install went really easy, did it the driveway with a floor jack and two jack stands.
Amazon.com: Flowmaster 817569 Force II 409S Stainless Steel Single Rear Exit Cat-Back Exhaust System with Mild Sound: Automotive
Seems like its not in stock. Would Amazon be the most reliable place to buy this from?
Sent from my SM-N900T using Tapatalk
22"magnaflow. Side exit 4" black tip.
Sounds ok but nothing like my 4th gen v8 with a 40 series flowmaster
Anyone install a Wicked Flow?
Hey everyone,
I used to have a wicked flow muffler on my Tacoma, it was great.
Do any of you know of anyone with them on their 4Runner?
I need to know what size and configuration to order.
Home
Thanks
Gibson isn't bad at all.. it is growing on me more and more every day. You can check out pics and sound clip in my build thread
