Axle shift
My panhard is pretty close to flat. Maybe a one inch drop on the mount would be nice.
I think the axle side would be the easiest to fabricate. The drop/rise should be equal to your lift. So, I would think most people would want to move it 2-3"
Trust me guys, you want to rip the axle side one off and weld a bigger one on. The leverage that mount will endure from an off road situation on a lifted and loaded for bear vehicle says to me that it isn't strong enough.
My jeep had a similarly designed and weight axle side mount and it was pretty common practice for anyone that was wheeling to strengthen the pre-existing mount or replace it all together. This was because it frequently was damaged or literally ripped off of the axle. The jerry rigged ways people got it to hold on till they could get home were impressive. Have you ever thought to wonder how many ratchet straps it takes to create enough friction to hold that thing in place on the axle tube for the journey home? It's not fun.
Someone commented that the track bar I was using on my jeep was bent. Yes, it was - but it was only so to clear the Dana 44HD differential that uses almost 3/4 ton ring and pinion sets. Being that he Toyota uses a fabricated housing with a 3rd member, the space requirements are much more lessened and a straight track bar can be utilized, which is more ideal.
In closing, be a man and buy the welder you always wanted. Or better yet, bring your truck to me and I'll replace your axle side mount for you for the cost of a case of your finest local craft non-IPA brew
Everyone with a 3 to 4" rear overland spring set that loads up and actually tackles trails that are more than just dirt roads should look at redoing/replacing the axle side mount
The stock mount looks pretty stout, but slapping an extension on it is probably a real bad idea.
I don't mind welding stuff, but that particular spot looks like a PITA job. Lots of stuff like brake lines, springs... would need to come out... Quickly turns into a major job.
Anyone know how thick the axle housing material is?
Pretty sure it's 6.5mm or just over 1/4"
I wonder how many Toyota's actually break those pan-hard mounts? I don't think I've seen that mentioned on the forums... You've piqued my curiosity now..
Plus no offense, but we're talking about Jeep here... those things were probably welded from the factory improperly with barely strong enough steel. (Not that Toyota's are made from solid Titanium or anything, just that I've seen enough of Jeep/Chrysler quality to forever be suspicious of there "engineering")
Guess I have this issue after all. Looks like I will be altering the fuel tank skid even more. I am still running the stock panhard bar.
Ha, this is an old post. Just to update it. I'm still on the stock panhard and mounts.. I just messed with the gas tank skid more to eliminate the rubbing. It still scrapes ever so slightly on rare occasions, but I can't really hear it. Just see the evidence of very sight scraping when fully tucked on the driver side.
Yes it is, but I remember the discussion, so I thought I would revive the thread. I am sure there are others out there who may not be aware that this is happening of where that noise is coming from.
For me, I have been looking for a use for the plasma cutter and welder. Fun toys!
FWIW- adjusting the bracket on the frame side is a better choice than the axle side.
[MENTION=118321]Jetboy[/MENTION]
I always appreciate your insights and understanding, but I'm trying to figure out what your illustration is about. It's not what a vehicle with a suspension system does, where the axle shifts up and down and stays fairly square and parallel to the frame (except when tucking wheels and shifting axles as [MENTION=106176]wfo9[/MENTION] has done).
What you've illustrated is an axle that's fixed to the frame on one side, which we all know it is not. Add the panhard bar fixed to the frame on one side and fixed to the axle on the other side of the differential. Then show the rotation of the bar as the axle shifts up or down. Sure, the axle rotates too, but it's only fixed in location by the trailing arms and laterally, left to right, by the panhard bar.
What we're talking about here is the panhard bar anchors to the frame and axle. The panhard shifts angle but not the axle under normal driving. If the axle rotates a bit as the vehicle goes over uneven terrain then the panhard bar shifts up or down depending on which side is tucking up under the body/frame.
I agree with what you said. It's probably better to shift the anchor point down from the frame. In the Rokeman photos I see two bolts that could be used to attach longer, lower triangular-shaped side plates to the existing anchor bracket and only marginally welded at one point inward from the existing anchor point. The 3rd point of the triangle would be pointed towards the center of the axle where it could be welded for increased stiffness of the plates. I can see it in my mind. I often detail stuff like this for static building designs.
I don't have any of those, but I'll contribute my opinion because I was one of the pioneers of 3rd gen modified rear lower control arms (RLCA's) back in about 2002. I might have been the first to catastrophically destroy my weak stock RLCA's on the trail. It's easy to bend the stock arms on rocks or ledges. So I'm a huge fan of upgrading RLCA's so the tube is a lot stronger than stock and potentially can also improve articulation.
First, the basics: SS has a pic on his web site comparing the stock tube thickness. If you're going off-road, you really should upgrade to anything that's about 1/4" thick wall tubing and roughly 1.5" diameter or so. You won't bend those.
I agree with the goal of having at least one rubber or poly bushing at one or both ends of any of the rear control arms. With the suspension design being a 5 link (4 links plus panhard), there are massive forces fighting between all the links with compression and tension in all of them, not to mention they still have to deal with rotation.
It's incredibly stupid to replace both ends of upper and lower links and maybe even the panhard with all "rod ends" / heims or Johnny Joints or any other joint that allows rotation but is otherwise rigid. If you have a ton of rod ends back there, you are guaranteed to "lock up" your rear end so it won't articulate, plus you'll likely break some bolts for those links, which a friend has done, plus you'll feel and hear a lot more vibations and noises. You can't assume that more rod ends equals more articulation -- that only works if you have something like a double triangulated 4-link or 3 link.
Many years ago I wheeled with Steve at Sonoran Steel. In the past I have disagreed with some of his conclusions, but in this case I agree with what he says on his web site about don't mess with the upper links - the stock upper links work great as is and it's very tight to try to adjust the length there anyway. There's very little motivation to do anything with the uppers. I also agree that it's not a bad thing to stick with rubber on both ends of the lower links, although I still think it can be a good thing to have only one end of the lower links with a high quality joint that allows good rotation.
What I don't understand about some of the new RLCA products is that the Currie Johnny Joint has very little room around it within the Toyota brackets for it to rotate much. It'll hit the side of the brackets pretty quickly because the joint itself is so wide. So then you're not fully utilizing the joint's ability to rotate and you might just be subtracting from the advantage of the flex of rubber joints at both ends.
I think it's a small advantage to being able to slightly adjust the length of either RLCA rather than just a rigid tube between rubber bushings at both ends. Yes, this can be useful if you want to make minor fixes to "yaw" or the pinion angle.
One of my early attempts at custom RLCA's used the stock Toyota rubber bushing on the axle end, a nice strong 1/4" wall 1.5" diameter DOM tube in the middle, and a 3/4" heim rod end at the other end. I had to drill out the bolt hole slightly larger from M14 to 5/8" to accommodate the 3/4" heim at the frame end. Unfortunately the 3/4" rod ends did not last long at all due to rapid wear. I tried a few different designs of 3/4" heims. I frequently struggled with squeaks although I tried to grease them and use heim boots on the sides to help grease them. I eventually gave up on those.
What I ultimately ended up with was to re-use those links with new threaded bungs welded in the one end of those tubes with the 7/8" Summit Machine Jimmy Joints. Those are basically huge heims that are rebuildable and greasable. One important point is they have much more surface area than any 3/4" heims. so one set of Jimmy Joints has lasted me almost 10 years and counting. I recently examined them and have no issues with them. I had to use medium strength threadlock on the ring in the side of that joint, but otherwise, I have no complaints about using them. I chose Jimmy Joints over Currie Johnny Joints because they are much narrower so they fit in the Toyota frame bracket with lots of room for rotation.
I utilized Spidertrax to assemble my original custom solution, although that's because they build control arms to your specs and they have a machine shop that can deal with the press-fit Toyota rubber bushings on one end. They don't have 4Runner products for this and they aren't familiar with my latest revision of these.
Sorry for the book. Yes, mine is a custom solution, but now you should have more knowledge to make a wiser choice for yours.
Resurrecting this thread (mistakenly also posted this in the 3rd Gen thread) as I look at getting my rear axle on my KDSS model centered. Anyone have any recent experience to share with rear Upper Links specifically? I am looking at getting the RESZ Fab Upper and Lower Links which are slightly longer than stock to account for lifts (which I have). However, I am also looking into getting the [MENTION=1795]sschaefer3[/MENTION] Sonoran Steel Panhard bar (with [MENTION=28464]eimkeith[/MENTION] Panhard Correction Kit), and noticed he sells Offset Lower Links also, but as [MENTION=165429]marmot[/MENTION] mentioned above, he does say the following:
The best replacement for the upper links is re-bushing your current stock links with the replacement Strong Flex bushings we sell or new stock upper links from the dealer. The reason why is that you can not make either the lower or the upper links longer than that are, because the upper link brackets on the axle tube already clear the Panhard/trac/lateral bar cross-member by millimeters. Longer links will collide on compression causing catastrophic damage. The upper links will never get hit by rocks and the stock units side twist quite well. The small diameter solid stock will also twist like a torsion bar.
Looking for any advice or experience. My plan is to move to extended travel rear shocks and 315/70s, but I want to make sure all the geometry is correct so I don't run into issue like [MENTION=106176]wfo9[/MENTION] and others have had with driveshaft contact on skids etc.
Correcting the geometry won't fix the tank skid intereference. (Tank relocation will)
Best you can do is adjust the axle offset to clear the tank - or clearance as needed...
But hey, if you guys need F150 tank mounts to relocate the tank to where the spare typically is like us 3rd gen guys do, let me know - I'm game. ;)
Wouldn't a longer adjustable panhard allow you to correct the side to side shifting of the axle from lifting? Helping to bring the driveshaft closer to it's stock location? Maybe I'm missing something?
His gas tank skid is not clearanced for the articulation. When Lil'Skip started making gas tank skids, he though he had it figured out. Then some of my customers bought them and all hell broke loose. I worked with him to re-design them so the shafts did not rub with the 1.2 kit. That was the end of that, not a very hard fix.
I have commented on this post previously with the issue. I have now eliminated the issue and am still running the Metal Tech LT rear set-up. I have clearanced the gas tank skid twice (documented in my buuid thread) and went to a Double Cardan rear drive shaft, which is smaller in diameter than the stock drive shaft and rotated the pinion up. I have no sway bars and still have stock panhard bar and mounting points. At full stuff on the drivers side, it is close, but no rub, so I'm content with my setup.
Sorry, I missed this last night - I have a tendency to go to bed early, and I don't get notifications from T4R for some reason..
So, an adjustable bar is great for re-centering the axle at lifted ride height and therefore beneficial to alignment & thrust angle, but any angled panhard bar will increase side-to-side shift during suspension travel, regardless of its length.
Here's an annoying video that illustrates this pretty well:
YouTube
(not sure how to embed video)
This is why a lot of folks comment that driving their 4Runner after leveling the panhard bar feels like running sway bars - the rear end wiggle has been significantly reduced.
As far as gas tank interference goes, re-centering the axle by lengthening an angled bar actually brings the driveshaft closer to the tank as the suspension compresses than it normally would be on a stock vehicle with a level/close to level panhard bar.
Imagine the illustration in the video reversed, so that the frame side of the panhard was on the right side of the screen like in our trucks - the angled bar causes the axle to travel to the left as the suspension compresses.
That said, I don't think Toyota built enough clearance into the tank & skid - they likely never suspected that we'd be out here flexing these things like we do. It's also my opinion that the offset weight and reduction in ground clearance make the factory tank a loser; albeit very well designed in every other aspect.
Persimmoncreek-farmer
