S&B Intake - 5th Gen via Burtman
Just installed mine today. As a heads-up, I cleared it with the dealership prior to buying. Their advice is that to avoid the risk of voiding the factory or extended warranty, buy the dry filter and not the oiled. This makes sense. I had an oiled K&N on my Xterra and it did mess with the MAF sensor that required monitoring and cleaning of both the sensor and the throttle body.
As for the S&B....
Fitment takes some work. The alignment holes require resizing, moving them closer together. The MAF sensor requires extra attention to install correctly, so be careful with this. There is an extra bracket - perhaps for the install of TRD instake box? - that needs to be massaged out of the way. I added some holes to mount the wiring harness (that the MAF sensor runs through) to the box.
Manufacturer instructions say to keep the optional portal open, so I did. Plan to install it in July, maybe, when temps get above 90 degrees on a daily basis.
Overall, not bad for the price. Install could have been cleaner for my 2019 SR5. But, it's up an running. Does have a howl when stomped on, but quiet when cruising. Will think about adding some thermal protective wrap to the tube and maybe some to the box as well....maybe.
Nope. Absolute false. Does not void warranty, I sell these to three Toyota dealers. There is also a law called the Magnuson act that protects you from anyone saying otherwise. [emoji1419]
S&B intake for 5th gen 4Runner at Burtman Industries
As for the S&B....
Hi Jason,
could you you comment on the difficulties people faces when install?
I guess smoother installation implies more units to be sold:flamethrwoer2:
Hey Y'all:
Put on the S&B intake on my 2018 4runner, and what a difference. The airbox is easily twice the size of the factory airbox. I have gained a little bit of mpg (about 0.5 mpg in the city, 0.9 mpg on highway driving). But the difference is the effortless of the acceleration. The engine runs smoothly and accelerates cleanly and doesn't feel clogged up or choke on hills. When I drive into the mountains is where this is most noticeable. I love it and it is worth the hour of installation. Thanks Jason!!!
NIce. So about 1 more MPG highway, that's decent. And less throttle to move you cause it lets you breathe easier.
Hi Jason,
Now have sold 20 and this intake is over $100-$150 less than the others. Haven't really gotten any calls with install except one guy that was missing instructions.
Burtman Industries S&B intake
ans here is the install. 75-5115.pdf - Google Drive And yes, carb approval for CA has been submitted so if you're in ca this will be able to pass soon.
Hi Jason,
I didn't think it was that hard. If you don't feel comfortable just grab a friend that you know is a gearhead and give him a few beers and do it together, or watch him do it while drinking beer. :tongue1:
Does this help those of use that live at 5k feet and spend a lot of time in 8k - 10k feet altitudes?
Yes, it does. I live at altitude as well, and this intake does assist with quicker throttle response and increased torque.
After a tank and a half, I am getting 21mpg. 21mpg is COMBINED city and highway. No CEL. There is a whistle that is now present, under load (not in neutral) between 2k rpm and 2.5k rpm. Will try to track it down at some point, but not too worried about it. I'm thinking it may be from the seal where the CAI joins up to the fender inlet. If anyone has any suggestions or insights, let me know. Still a good buy though. Would still purchase over K&N or AFE.
yea it's the cheapest one too and seems to be very good quality. The AFE is looked at was $150 more! I'm showing about 1 more mpg with this. What are you showing over yours when it was stock with your current numbers?
Does it have a laminizer to help reduce air turbulence? It would look like some sort of grid that "straightens" air to improve its entry efficiency. Bulk volume isnt everything.
Neat looking box all the same. Any dyno results?
and here is the install. 75-5115.pdf - Google Drive And yes, carb approval for CA has been submitted so if you're in ca this will be able to pass soon.
See above to order.
Correct. It's the best one for the PRICE for out of all the ones I've sold.
there isn't an issue with the hole alignment?
That said the S&B seems to be the one I'd get.
I have heard that the opening to the bottom of the airbox is difficult to line up on the newest year but it's possible it's just something off a little by Toyota or customer may not have had a beer before install :) I think I had a 2019 where customer had to make the one hole larger on intake then use a washer to cover in in case it gets too wide for the bolt.
I have most reporting about 1 more MPG driving, which is also nice.
Picked up and installed my S&B intake from Jason back in June. Installation was extremely easy. I did have to bore out one of the holes in the bottom of the air box to make it fit, but we're talking a millimeter or two.
As others have mentioned, about a 1 mpg increase in mpg. No significant power gains (as expected) but definitely a smoother power band.
Looks and sounds great!
Excited to eventually add the Gibson Exhaust and Sprint Booster from Burtman Industries.
Thanks Jason!
Thanks Jason!
[MENTION=409136]DCassan[/MENTION] - Thank you for the feedback! 1 more MPG is great. And I'm having customers tell me they're getting about 1 more mpg with the Sprint Booster too!! No joke. see more here on that:
Sprint Booster SALE for 5th gen 4Runner, Limited time...
S&B intake at Burtman Industries
[MENTION=409136]DCassan[/MENTION] did you get the Sprint Booster installed?
I did get it installed late last week. It's like a whole new ride with how quick the acceleration pops after giving it some gas! I haven't seen any change in my gas mileage to this point, like some have mentioned, but it has only been a week!
Cool! Yea, you need a wait a few weeks and then when you're fully back to driving normal you will see it.
Also, on the sprint booster I've have people reporting about 1 more mpg. Again, this is after you start driving normal and not flooring every few min to test the upgrade :)
Burtman Industries Sprint Booster, you can send it back if you don't like it! - You can also call your order in or text with any questions, 717-319-2100
kimyuseung77
