03-04-2020, 11:03 PM
#16
![Bugser's Avatar](https://www.toyota-4runner.org/customavatars/avatar75046_1.gif) |
Real Name: Bob
Real Name: Bob
I like the CaliRaised Tri-color LEDs
2018 TRD ORP, MGM, Xpel 35% Tint, Xpel Clear Bra, In-Dash 2m/70cm Icom Radio, Dual-band 1/4 wave antenna with Rago Mount, sPod Bantam, 2 x 32" behind the grille LED lightbars, Cali Raised 3-way Fog Lights.
Sold: 2011 SR5
03-04-2020, 11:37 PM
#17
Originally Posted by BamaT
Did the lamin-x films reduce output significantly of the LED bulbs? I was planning on going this route, OEM LED fogs with lamin-x yellow film for yellow output.
I am curious about this too.
2020 Runner TRD Offroad Premium w/KDSS and Moonroof | RSG Sliders | TRD Pro Rims | BFG KO2s | Hikari Ultra (Low and High) | Toyota OEM Black LED Fogs | Focal IS 690 with EOM audio tweeters | Focal IC 165 | OEM Audio Plus System 500 with Dedicated Sub Amp
03-05-2020, 12:10 AM
#18
Diode Dynamics SS3 “Sport” fogs. Easy replacement. Built great, look great. Really happy with them.
2017 Limited in Magnetic Gray
3rd row, Weather-Tech floor mats, center console tray.
LIGHTING: XD HID Headlights w/Phillips 4300k, XD LED Extreme Hi-beams w/DRL driver, Diode Dynamics SS3 "Sport" Yellow Foglights, LASFit switchback LED front turn signals, JDM ASTAR 2000 lumen reverse bulbs, LED interior accent lighting.
03-05-2020, 10:09 AM
#19
I have stock fogs with with the lamin x yellow and the output is fine. So with LEDS I’m sure it won’t affect it at all.
03-05-2020, 12:05 PM
#20
I have LED fog bulbs with the laminx yellow and have no issues.
To the OP, I'd suggest to start with the laminx unless you really need more light output and want to replace the unit itself or just the bulbs.
03-05-2020, 01:08 PM
#21
![90Duck's Avatar](https://www.toyota-4runner.org/customavatars/avatar236329_7.gif) |
Real Name: Dale
Real Name: Dale
I have no way of quantifying it objectively, but from behind the wheel I'd say no. Those Tundra OEM's are a super easy plug and play replacement and are really bright, but in a very focused horizontal band with distinct cut off. I put yellow film on there originally and it shone through so brightly that you couldn't even really tell they were yellow. The amber film laminx is thicker and darker and I like the look much better when they are off and it I believe it visually cuts glare in fog/snow when on, which is what they are intended to do.
“Having aspirations is not the same as achieving them”
- Mr. Regular
Finn the 2018 Super White ORP
03-05-2020, 07:41 PM
#23
Do the OEM LED fogs have a replaceable bulb? I'd like to use a yellow bulb instead of a film.
03-05-2020, 07:58 PM
#24
![shrub1's Avatar](https://www.toyota-4runner.org/customavatars/avatar142164_1.gif) |
Tell me about the Tundra OEM fog lamp swap to the 4Runner. Does the Tundra lamp fit right in the 4R bezel or is there modification involved?
03-06-2020, 02:47 PM
#25
Real Name: Dale
Real Name: Dale
No modification required at all, it was a direct fit replacement on my '18. You will be blown away by how crappy the build quality of what comes stock on the 4Runner is compared to the LED upgrade.
Amazon.com: Toyota PT413-42191 Black Fog Light: Automotive
- Mr. Regular
03-06-2020, 03:41 PM
#26
Yes, the bulbs are replaceable.
03-06-2020, 10:22 PM
#27
Do you know if they are halogen or led?
03-07-2020, 09:36 AM
#29
![Salvo Jimmy's Avatar](https://www.toyota-4runner.org/customavatars/avatar100784_1.gif) |
Real Name: Ted A Hamilton
Originally Posted by ElectroBoy
Very interesting, especially the remark about no yellow bulb that does the job available.
BTW for Virginia folks be advised that only clear film can be placed on lights. I ran into this with Laminex on my T4R and could not pass state inspection until I removed it. And yes I had the inspector show me the requirement in the book, as I was highly skeptical.
Ted A. Hamilton
(aka Salvo Jimmy)
Glen Allen VA
2022 SR5 Premium 4WD
No Mods, Yet😇
03-09-2020, 03:02 PM
#30
Real Name: Dale
Real Name: Dale
They are LED.
- Mr. Regular
