4RExplorer
In the cargo area, I am replacing the carpet with a rectangular piece of plywood that fits between the wheel wells. To bolt its rear corners down, I drilled out the sheet metal floor to reveal two threaded holes that I believe are normally used to bolt down Toyota's slidng cargo tray (which I don't have). It took a little trial and error to find their location.
The photos show the threaded holes after I drilled them out, on the driver's side and the passenger side. In each photo, the short red arrow from the center of the threaded hole is 1 3/16" long, and the long red arrow is about 9 13/16" long. Each long arrow ends at the center of a hole near the black weatherstripping of the rear hatch (visible at the bottom of the photos).
I started with a narrow drill bit and gradually widened the hole with larger bits, and cleaned up the edges with a tiny triangular file before applying rustproofing primer with a toothpick.
